Author Topic: Heater Broke ????  (Read 2920 times)
Offline workhorse '90 8v
Heater Broke ????
« on: 22 November 2003, 11:27 »
Heater broken. It still blows, but only luke warm.  Any ideas?  Only thing checked so far is the fuse, which is fine.   I did have the dash/trim/etc off the other day to change the speedo cable, could i have knocked/broken something in the process..?
Any help much appreciated, frosty this mornin, brrrrrrrrr!!
Offline dubslug
Re:Heater Broke ????
« Reply #1 on: 22 November 2003, 16:58 »
remove or change the water by pass valves in the engine, worked for me
1992 pearl grey 8v
Offline m4nesh
« Reply #2 on: 22 November 2003, 18:23 »
my heater only gives out luke warm air too?
Flushed radiator, - no joy
Might try that by pass valve thing? Check other post for part number?
« Reply #3 on: 22 November 2003, 19:48 »
where's that VR6 bloke ?  he knows his stuff ..
Veedubgt18v
« Reply #4 on: 22 November 2003, 20:32 »
maybe your heater matrix has gone up the spout?
Offline jedi16v
« Reply #5 on: 22 November 2003, 23:04 »
i had the same problem . the bloke who had my car before me fitted a new heater matrix but still only cold air . thanxs to this forum found out about the bypass valve's fitted new ones from volkswagon and they worked a treat . they cost about ?28.00 inc VAT which is'nt bad for volkswagon . lots of lovely heat . real toasty . oh and they only take about 10 mins. to fit bargain!!!!!
golfvr6
« Reply #6 on: 23 November 2003, 00:45 »
Changing the by-pass valve does seem to cure the problem in most cases.
Offline modulater
« Reply #7 on: 23 November 2003, 00:47 »
At 28bar be silly not to give it a go
