Author Topic: Mk2 Golf GTI 1989 16valve Starting problems  (Read 1716 times)
Offline veedubmk2golf
« on: 07 March 2006, 19:03 »
I recently had my clocks out and everything went wrong, when it started it would cut out within 5 Min's, i fort this was the alternator as the battery light stayed on and thats a sign of a faulty alternator so i replaced it with a reconditioned one. I've tried junks leads and it wont even start now, its trying but it wont fire up.  its not the battery as i've had it tested and its fine, can any1 help me as i would be very grateful or reccommend any1 who could fix this
« Last Edit: 07 March 2006, 19:33 by vwcheshire »
Offline monzablue16v
Re: Mk2 Golf GTI 1989 16valve Starting problems
« Reply #1 on: 07 March 2006, 19:39 »
Sounds like a plug is not connected properly on the clockset I'd take tham out and check them or try a cheap replacement from ebay?
« Reply #2 on: 07 March 2006, 22:23 »
If the blue wire from the alternator to the clocks is broken the alternator wont charge the battery, and the warning light will be on constantly.  Check the wires to the clock plugs to make sure they are all connected properly.
Offline stan_deezy
« Reply #3 on: 08 March 2006, 08:31 »
Silly question but did you refit the rubber hose into the back of the clocks? It shouldn't stop it starting but it wouldn't help it.
« Reply #4 on: 08 March 2006, 12:45 »
yes i have connected the vaccum pipe back and the mfa is working properly, i cant understand why it wont start now and it did b4 because i've not driven it any where, i've made sure the plugs are connected properly, i've had all spark plugs out to clean them and it still wont start, it can't be anything mechanical surely as the engine was fine before i messed around with the clocks.
Offline Gambit
« Reply #5 on: 08 March 2006, 13:47 »
is the wiring on the back of the iginition barrel all secure?
« Reply #6 on: 08 March 2006, 21:55 »
yes all the wires are secure and there is plenty of petrol too, i just cant understand why it wont start, my friend thinks that an earth may of come loose or split.
« Reply #7 on: 09 March 2006, 10:05 »
Get the battery charged up and give it another go!
Offline Outlaw-Torn
  • Let me try that again, with a bit less stupidity..
« Reply #8 on: 16 March 2006, 00:11 »
Is the starter motor turning at all? If the starter's turning but the engine won't fire, check you put the plugs back in the right order. If the starter won't turn, try another battery
'I've got your mother's maiden name tattooed on my arm...'
