Author Topic: Whats this hose?  (Read 2094 times)
Offline toddy98274
Whats this hose?
« on: 06 March 2006, 11:48 »
I replaced the throttle body on my GTI 8v (AGG code) at the weekend in an attempt to cure its stalling problem.
Fingers crossed, so far this seems to have worked and it has not stalled since it was replaced
Something I did notice when I was taking all the various hoses off the throttle body was that one of them was completely clogged up with gunk which didnt look too healthy
The pipe actually feeds off the main air intake pipe that comes from the airbox towards the top by the throttle body, it then goes underneath a black plastic cover on top of the engine block (this cover is held on by 2 screws) and then goes down towards the bottom of the engine where it stops.
Might be a really bad description but I am not particularly mechanically minded so this is the best I can do
If anyone can identify what this hose is from the description I would appreciate some advice on whether this pipe should be full of cr*p (i assume not though), what it does, whether it is easy to replace and even possibly why it would get full up in the first place ie is there something wrong elsewhere?
Any help appreciated
Offline Dom Mk3
  • Insert wit here
Re: Whats this hose?
« Reply #1 on: 06 March 2006, 12:25 »
that's the oil breather... it should have some oil residue in there but not "full of gunk".
Clean it out, then see how dirty it gets after a short while. It might just be many years worth of oil clogging it up...
Offline toddy98274
« Reply #2 on: 06 March 2006, 14:01 »
Hi Dom
How do i go about taking this off? As I unscrewed the two bolts described but it didnt seem to want to come away from the top of the engine without a reasonable amount of force.
Is it ok just to use brut force to get the hose off or am I likely to do some damage?
Offline Dom Mk3
  • Insert wit here
« Reply #3 on: 06 March 2006, 14:48 »
have you got a photo of the engine bay? just reread your post and noticed you said it went to the bottom of the engine...
Offline toddy98274
« Reply #4 on: 06 March 2006, 15:06 »
I havent got a photo to hand but I will try and get one on here tonight
Offline monkeyalan
« Reply #5 on: 06 March 2006, 15:25 »
http://www.golfgtiforum.co.uk/index.php?topic=34212.0
you can see it here.  can't remember where it goes off hand.
Offline toddy98274
« Reply #6 on: 06 March 2006, 16:14 »
Thanks monkeyalan I was searching for a decent photo but had no joy
I have arrowed the parts which I was trying to explain earlier so hopefully this will now be more clear
The top arrow is pointing at the start of the hose where it joins the main intake pipe
The middle arrow is pointing to where this hose goes into the top of the engine underneath the plastic cover which I have tried to undo and remove
And the bottom arrow is pointing to this same hose which is now going to the btoom of the engine (which cannot be seen)
It looks as though this pipe is one continuous line so I would assume it would all need to be cleaned or maybe even replaced
Let me know if you have issues seeing the photo as I havent posted any before!!!
Offline monkeyalan
« Reply #7 on: 06 March 2006, 16:25 »
they're both just breathers for the oil. they should be cleaned out if they're ful o crap.
Offline Bazzer
« Reply #8 on: 06 March 2006, 16:29 »
I did this on myne after I got it - just gently pull the end off the cam cover (it's like a 2 - into - 1 effort). The other end if Veedub's own hose clip nonsense - just break it open and use a normal hose clip in it's place.
Easy mate...  :smiley:
Bazzer
Offline toddy98274
« Reply #9 on: 06 March 2006, 16:46 »
Sounds easy enough then ill give it another try
Should the plastic cover on the top of the engine which covers where the 2 hoses join come off on its own or is this attached to the pipes somehow as it definately didnt want to budge after I removed the 2 bolts
I must be missing something so ill give it another go and let you knwo how I get on
Thanks for your help
