Author Topic: brake discs??????  (Read 1952 times)
Offline nadlad
  • Building Surveyor MRICS
brake discs??????
« on: 27 February 2006, 20:21 »
this sounds really dumb but how many brake discs and pads do u ned for a 1.9 tdi se pd 100 ona 02 plate thanks
<<<Big Build Thread>>>
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: brake discs??????
« Reply #1 on: 27 February 2006, 23:32 »
Dunno about the TDi, but my 1.8 T has a front & rear disc setup.
Front & rear pads for discs, both come as a set anyway (4 in a box - 2 for each disc)
Discs are sold seperately.
For example, for a full brake replenish, I would need 2 x 283mm discs for the front, & 2 x smaller discs for the rear, along with 1 set of front, & 1 set of rear pads. :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline nadlad
« Reply #2 on: 28 February 2006, 10:16 »
thanks mate i think on mine its only the front that have the wear indicators so that must mean i wud need
2 x front discs 2 x rear discs
1x front pads with wear indictors
1 x rear pads
« Reply #3 on: 28 February 2006, 12:06 »
Yes, only the front N/S has the indicator, so can only tell with rears by looking.
I take it you've had the 'Check Brake Pads' sign light up the dash, then?! :grin:
If in doubt, I'd get it checked out at one of those 'free brake check' centre's, as you don't want to buy discs/pads all round, if you only need front pads, for example.
Offline nadlad
« Reply #4 on: 28 February 2006, 12:48 »
using eurocarparts.com am looking at just getting standard everything as am on a low budget and student loans company are paying!!!!
ave come up with this bearing in mind all pads and discs need changing:
Part Number     Part Type                    Description                                                       Total
104440740 REAR DISC                    GOLF4 ALL MODELS £17.33                               Ãƒâ€šÃ‚£17.33
101440325 REAR BRAKE PADS         GO/VE//CO 92- £14.65                                     Ãƒâ€šÃ‚£14.65
101440675 FRONT PADS GOLF4 WITH WEAR INDICATOR                                         Ãƒâ€šÃ‚£29.98
104440720 FRONT DISC GOLF4 280X22 15 INCH AGN,AGR,ALH,AHF, 1.8/1.9          £26.25
        Subtotal: £88.21
        VAT: £15.44
        Total inc shipping: £103.65
brake pads and discs are made by ATE.....what do u think is 100 quid inc shipping and vat a good deal?
« Reply #5 on: 28 February 2006, 12:58 »
http://www.buypartsby.co.uk/
I usually use these, as online, GSF have a habit of listing mixed up part no's.
