Author Topic: K-Jets & Warm Up Regulator relocation  (Read 5185 times)
Offline Gambit
« on: 20 November 2003, 11:38 »
Offline Fraiser
Re:K-Jets & Warm Up Regulator relocation
« Reply #1 on: 20 November 2003, 12:04 »
ill try that later on today.
Offline Gambit
« Reply #2 on: 20 November 2003, 14:05 »
bit of an update, this is for 8v WUR's only - as 16v WUR use a vacuum assit
so if you have an 8v your better of just replacing it with a 16v WUR!
Blue MK2
« Reply #3 on: 20 November 2003, 14:11 »
Gambit,
Im still a beginner. Can you tell me where the ware up regulator is mate?
Offline Gambit
« Reply #4 on: 20 November 2003, 14:59 »
not really sure about 8v's, ill hazard a guess and say it'll be on the side of the block and have a couple of fuel pipes running to it
should just be a bit below the coldstart valve
Offline modulater
« Reply #5 on: 22 November 2003, 15:12 »
On an 8 Valve the warm up regulater is on the front of the block just above the distributor. On a 16V is on the side of the block, gearbox end.
One thing if you get a vacuum assist Warm Up Regulator you are gonna have to get a fed for it from the inlet manifold so may have to tap and drill it.
Offline miguel
« Reply #6 on: 24 November 2003, 13:12 »
if your currently ok then don't bother! all you'll do is make it run too rich. if you f*ck up the fuel air ratio you'll either a, run too lean go slower and burn a hole in your piston!
or b, run too rich go slower and burn a hole in your wallet!
if you haven't got access to a rolling road you can't set up the fuelling other than guestimating
golfvr6
« Reply #7 on: 24 November 2003, 14:39 »
You can set up fuel/air mixture with a co tester or a gunston colortune.
Offline miguel
« Reply #8 on: 24 November 2003, 16:24 »
....not with the engine underload you can't, unless you take the bonnet off and sit on the front wing while your mate drives....
Offline mk1
« Reply #9 on: 24 November 2003, 19:50 »
Or set up the mixture on the road with a air/fuel meter, like I have ;).
Steve.
