Author Topic: fault codes. Dump valve....1.8T  (Read 7073 times)
Offline Mr Blue
« on: 26 February 2006, 01:06 »
1.8T AUG engine
what do these fault codes mean exactly?....
17608 (P1200)---Unknown trouble codes
17705 (P1297)---Unknown trouble codes
17545 (P1137)---Unknown trouble codes
i know the first one is the dump valve which is faulty.
Did that cause a chain reaction and set off the other fault codes if you know what i mean? :rolleyes:
how much are standard dup valves from VW stealerships?
chers
Blue :evil:
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: fault codes. Dump valve....1.8T
« Reply #1 on: 26 February 2006, 09:36 »
Standard dump valves are about £16 and i'll take a look in to the codes for you in a minute.  If i were you tho, I'd use it as an excuse to buy a bailey/forge
Offline GazB
« Reply #2 on: 26 February 2006, 09:40 »
Cant find the P1200 code, P1297 Connection turbocharger - throttle valve pressure hose, P1137
 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich. :wink:
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 26 February 2006, 10:02 »
that one is getting more and more common.. looks like the vacuum hose for the dv wasnt built to last by vw :sad:
Offline richandhazel
« Reply #4 on: 26 February 2006, 11:26 »
Gaz, where have you cross referred those fault codes from?
kingturbo
« Reply #5 on: 26 February 2006, 12:12 »
couldnt someone put a sticky on a fault codes topic so people can add their codes and what they mean so we could look them up when we get them
just an idea
« Reply #6 on: 26 February 2006, 17:33 »
Good idea mate. I'll see what Gaz says and then probably go on to instigate that myself :wink:
« Last Edit: 26 February 2006, 18:45 by richandhazel »
Offline Mr Blue
« Reply #7 on: 26 February 2006, 19:12 »
so is the mk4 ok to drive here and there or will this kill the turbo?
where do i start. what should i do. I no nothing about mk4's  :undecided:
thanks people :)
kingturbo
« Reply #8 on: 26 February 2006, 20:02 »
:smug:
Offline GazB
« Reply #9 on: 26 February 2006, 23:14 »
Sorry for the late reply :angry:, they were from bently publishing site
http://www.bentleypublishers.com/tech/vw/vw.dtc.table.htm
 :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool:
