Author Topic: amp wires  (Read 2909 times)
Offline dubslug
amp wires
« on: 24 February 2006, 10:40 »
if i run power cable down passenger side of my car for the amps
rca cables down drivers side
where is best place to run remote and speaker wires plz  :embarassed:
cheers rik
1992 pearl grey 8v
Offline Nickyb
Re: amp wires
« Reply #1 on: 24 February 2006, 11:00 »
Remote the same side as the power, speaker cables down the same side as the rcas.
All the power down one side, all the signal cables down the other side.
Offline dubslug
Re: amp wires
« Reply #2 on: 24 February 2006, 13:38 »
cheers for ur help
now next problem, got a four channel amp if i only use 2 channels its fine, if i try and use four channels it gets major engine interferance, blown amp??
tried rewiring,rcas,earth points, head unit etc
any help guys??
1992 pearl grey 8v
Offline Dom Mk3
  • Insert wit here
Re: amp wires
« Reply #3 on: 24 February 2006, 14:20 »
so you can use channel one on its own fine and channel two on its own fine but not both together?
Offline dubslug
Re: amp wires
« Reply #4 on: 24 February 2006, 14:35 »
i can use channel one and two say for front speakers but as soon as i try and connect rca so i can use channel three and four it gets major interferance
1992 pearl grey 8v
Offline Dom Mk3
  • Insert wit here
Re: amp wires
« Reply #5 on: 24 February 2006, 16:20 »
have you tried unplugging the rca's that you were putting into channel 3/4 and putting them in channel 1/2?
Offline Dizzie
  • Make friends with your fast
Re: amp wires
« Reply #6 on: 25 February 2006, 15:18 »
what amp is it?
Mk4 Golf 150PD
Offline dubslug
Re: amp wires
« Reply #7 on: 27 February 2006, 10:14 »
ive now tried a few amps, one was a pioneer which my mate has in his car working fine,
since this interferance started i have redone all wiring, replaced rcas,redone earth,changed headunit,amps, the intererance isnt there till car is started and engine is running, im just wondereing does the alternator have a supresser on it??
reason i ask is because my battery light nevre goes out til i rev the car a bit, also it wines loads like its whistling at all the girls, but its the same kinda noise as in the stereo
1992 pearl grey 8v
Offline j_s
Re: amp wires
« Reply #8 on: 27 February 2006, 10:27 »
Noise is normally to do with earths, what size earth cable are you using and where is the main earth in the boot?
The battery light shouldn't stay on, it should go out almost immediately the car is started not after you have reved it a bit. You might want to try a new voltage regulator on the alternator.
James
Offline dubslug
Re: amp wires
« Reply #9 on: 27 February 2006, 22:37 »
think its 4 gauge earth, its almost as thick as say a packet of polos
its secured to where the seats attach at the front by the screws, its good clean metal there took me an age to do it
cheers for all the replies all, i do appreciate them, keep the ideas coming
1992 pearl grey 8v
