Author Topic: wiring probs  (Read 2932 times)
Offline dubslug
wiring probs
« on: 22 February 2006, 21:00 »
hey all, my iso block has been cut apart and put back toghether but im a little concerned
i have a main thick red wire coming out of iso block,this has been connected to a thinnish brown/red wire
then there is a thinnish brown/red wire that is connected to thick red wire, how come these have been switched around?? if i put them red on to red etc it wont work??
any ideas??
1992 pearl grey 8v
Offline Dom Mk3
  • Insert wit here
Re: wiring probs
« Reply #1 on: 22 February 2006, 23:15 »
isn't brown/red the ignition feed on some golfs?
anyway, can you take a photo of it?
Offline Ozz
Re: wiring probs
« Reply #2 on: 23 February 2006, 01:00 »
Hmm, I'd just chop it out and wire in a new iso block. I generally connect the live and switched live from the radio to the permanent live from the car, so the radio doesnt switch off when the ignition is turned off. Always get annoyed when I'm listening to a song when I pull up and it goes when I turn the ignition off!
Mk2 Gti 8v
Offline dubslug
Re: wiring probs
« Reply #3 on: 23 February 2006, 10:42 »
think ive done that on the radio wiring side of things
it just seems odd someone has chopped the two wires and swapped them over, just wondered if there would be a reason??
1992 pearl grey 8v
Offline Dom Mk3
  • Insert wit here
Re: wiring probs
« Reply #4 on: 23 February 2006, 13:16 »
Ah I see what you're getting at now. It'll be permanent live and ignition swapped. On Golf's they're the wrong way round as standard. Not sure if that applies to the later ones...
Offline dubslug
Re: wiring probs
« Reply #5 on: 24 February 2006, 10:16 »
mines a mk 2 so im guessing its now the right way round and i should just leave it alone then??
1992 pearl grey 8v
Offline Dom Mk3
  • Insert wit here
Re: wiring probs
« Reply #6 on: 24 February 2006, 13:39 »
sounds right to me :smiley:
Offline dubslug
Re: wiring probs
« Reply #7 on: 24 February 2006, 14:35 »
ok its left alone
1992 pearl grey 8v
