Author Topic: Mk2 Rear Calipers  (Read 2139 times)
Offline davidhawkins_78
  • Valver Bad Boy
Mk2 Rear Calipers
« on: 18 November 2003, 10:17 »
Hey peps - I know this is a common problem on Mk2's but I have a '89 8v and it's nearly MOT time i need to cut some corners to get the rear calipers / handbrake mechanism working to pass !
The Mk3 Calipers will need modded to fit, but I've heard you can refurb / clean old calipers for a short term fit. I've checked the Haynes manual and not found much detail so was wondering if anyone can give me some advice ....
PS ... (The actual caliper is fine, it's just the handbrake mechamism)
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline Gambit
Re:Mk2 Rear Calipers
« Reply #1 on: 18 November 2003, 11:22 »
if you disconnect the handbrake cables, you can knock the handbrake rachet & spring out about 1/2 inch, give the rachet a good rub with wet & dry to remove all traces of rust, then drown it in wd-40, let it seep in, then plaster it in grease and knock the rachet back in
you can also use ford granada return springs which are stronger than the VAG items
this is the ford part nums for them
6 141 147 and 6 141 148
if your car has the later spec mk2 calipers with the handbrake cable on the rear of the caliper then yes they are a straight swap with the mk3 calipers
but if they are the earlier calipers then you need to reroute the handbrake cables
golfvr6
« Reply #2 on: 18 November 2003, 11:31 »
Spot on there Mr.Gambit  :D  I would get rid of the old mk2 calipers if you can afford to, the mk3s have internal mechanism and don't seize all the time.
« Last Edit: 18 November 2003, 11:35 by golfvr6 »
  • Valver Bad Boy
« Reply #3 on: 18 November 2003, 15:31 »
Cheers Guys - I'll definately be getting rid of these pesky 'Barstewards'as soon as I can - just need that MOT to keep the old bill away ...
Offline modulater
« Reply #4 on: 19 November 2003, 20:43 »
You can buy the calipers in a kit that comes with all the pipes you need, although its a piece of piss to make up your own.
