Author Topic: Easiest engine upgrade  (Read 8852 times)
Offline Dan_Dub
« on: 08 February 2006, 18:14 »
me & my mate have just a mk1 with the intention of obviously having it as 'the project car'  :grin: we were wondering what the best/easiest engine upgrade was?
we have read that a polo g40 engine will go in very easily without much work, anyone know of any other ideas...just put em down
cheers
Offline Mr V Wagon
Re: Easiest engine upgrade
« Reply #1 on: 08 February 2006, 21:53 »
I take it it's a 1.1 or 1.3? :huh:
Mr V - 2.0 8v 14.6 @ Pod - N.London Elite1000 Ace Cafe -  E1K Forum
Offline Tucker
« Reply #2 on: 09 February 2006, 15:04 »
would like to know the same for a 1.5 carb :smiley:
cheers
Tucker
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline Dan_Dub
« Reply #3 on: 09 February 2006, 15:33 »
its a 1.1, literally down to a bare shell, getting a respray then thinking about doing the engine next.
so any ideas...
cheers
Offline mk2_singh
« Reply #4 on: 09 February 2006, 16:40 »
1.8 gti from mk2. cheaply available and should be a bolt as you go i think..
Offline robiwill
« Reply #5 on: 10 February 2006, 01:26 »
K jet late Mk1 engine is the easiest or a 16V conversion. although I know of a Mk1 with a 20V turbo now this is a lot of work
Offline monzablue16v
« Reply #6 on: 10 February 2006, 10:22 »
VR6 will go in with a bit of swearing :D
Offline mk2_singh
« Reply #7 on: 10 February 2006, 21:21 »
vr6 powered mk1 know that would be sweet!
Offline BobbyT
« Reply #8 on: 11 February 2006, 05:00 »
not too sure about the vr6 lump, sounds good but i think it goes against the light weight principle of the mk1, it makes the front end far too heavy! the 2.0 16v is a good option! if you have the time money and know how do the 1.8 turbo route!  :grin:
Offline Mr V Wagon
« Reply #9 on: 12 February 2006, 16:36 »
For the 1.1, the easiest route would probably be a G40. If you're looking for a 1.8 lump, the O/S engine mount off the 1.8 car would need to be removed and rewelded into the 1.1 as they're different. Then you'd have to scrounge all the fuel system off a GTI too.
For the 1.5, the engine mount is the same as the 1.8 but you'll also need to change the fuel system.
If you're going to go through the hassle of changing the engine, you're better off doing a 16v conversion. It's the same amount of hassle as putting in a different engine with only 1 minor wiring loom to sort out.
A 2.0 16v with 1.8(KR) cams is 150bhp straight out of the box.
V
