Author Topic: Easiest engine upgrade  (Read 8853 times)
Offline Tucker
Re: Easiest engine upgrade
« Reply #20 on: 21 February 2006, 22:48 »
Better get me that bottom end then :smiley:
Thanks for the info mr v, will prob give ya a shout at some point :laugh:
Tucker
http://i10.photobucket.com/albums/a109/sydney04/mk116vsmallpic.jpg
Sig too large, see forum guidelines - Admin.
Offline Mr V Wagon
« Reply #21 on: 22 February 2006, 21:35 »
No worries mate :cool:
Mr V - 2.0 8v 14.6 @ Pod - N.London Elite1000 Ace Cafe -  E1K Forum
Offline Anni96
« Reply #22 on: 23 February 2006, 14:04 »
For the 1.1, the easiest route would probably be a G40. If you're looking for a 1.8 lump, the O/S engine mount off the 1.8 car would need to be removed and rewelded into the 1.1 as they're different. Then you'd have to scrounge all the fuel system off a GTI too.
For the 1.5, the engine mount is the same as the 1.8 but you'll also need to change the fuel system.
If you're going to go through the hassle of changing the engine, you're better off doing a 16v conversion. It's the same amount of hassle as putting in a different engine with only 1 minor wiring loom to sort out.
A 2.0 16v with 1.8(KR) cams is 150bhp straight out of the box.
V
hi, why are the 1.8 cams better than the standard ones?  :undecided:i am guessing the kr cams are from the 1.8 16v? rob  :smiley:
Offline BobbyT
« Reply #23 on: 23 February 2006, 14:14 »
^^^^^ sorry, that was me posting!! not sure why i am sum bird called anni??? very odd! oh well back to normal now!! lol  :laugh:
Offline Mr V Wagon
« Reply #24 on: 24 February 2006, 18:42 »
lol! :grin:
The KR(1.8 16v) engine has a longer duration inlet cam :wink:
Offline BobbyT
« Reply #25 on: 25 February 2006, 18:12 »
^^^ ok..... but can you give me that in laymans turms? what will this do to the car will the power kick in lower down?? i am a bit of a retard when it comes to cams!!  :grin:
Offline Tucker
« Reply #26 on: 25 February 2006, 18:42 »
The KR cam has a bigger inlet lobe on the cam which means the inlet valve stays open longer than a normal cam :cool:
More fuel, air = power
cheers
Tucker
« Last Edit: 25 February 2006, 18:46 by Tucker »
Offline Mr V Wagon
« Reply #27 on: 25 February 2006, 19:20 »
Exactly :cool:
