Author Topic: Engine mounts???  (Read 2140 times)
Blue MK2
Engine mounts???
« on: 16 November 2003, 18:50 »
Ive got a firm suspension setup. Ive just overcome a 'click' noise from the front topmounts but now i get a loud rattle.
Im thinking the engine mounts are causing that rattle noise?
Also when the car is on the 'biting point' it makes that rattle noise.
Must be the engine mounts then. what you think ?
golfvr6
Re:Engine mounts???
« Reply #1 on: 16 November 2003, 22:26 »
Could well be. Get a mate to rev the engine on the clutch while you watch it leap up, watch for excessive movement at any of the mounts.
Blue MK2
Re:Engine mounts???
« Reply #2 on: 16 November 2003, 23:05 »
im pretty sure its the mounts. How many are there to change and is it easy?
Offline Gambit
Re:Engine mounts???
« Reply #3 on: 17 November 2003, 08:54 »
there is 3 mounts, front, rear & gearbox mounts
you can use the later hydro mounts found on the 16v for the front & rear, and just use a std gearbox mount.
http://www.vwspares.co.uk are the cheapest i've found for the mounts
i got charged 2 hrs labour for fitting all 3 mounts
Offline modulater
Re:Engine mounts???
« Reply #4 on: 19 November 2003, 21:53 »
fairly straightforward as long as you have a decent trolley jack to change them.
« Last Edit: 19 November 2003, 21:54 by modulater »
