Author Topic: starter motor on way out ?????????  (Read 676 times)
Offline the.little.fox
« on: 05 February 2006, 12:20 »
hi
sometimes (quite often) when i turn the key i get a loud sharp ckckrwrrrkcccrrrrr (crunch?)
turn key again, same again
turn key again, she starts, yey!
so, starter on way out? or something else?  (checked battery - 12.51volts)
thanx
Offline TIM20
Re: starter motor on way out ?????????
« Reply #1 on: 05 February 2006, 13:56 »
yer sounds like the starter is sticking, try taking it off and throughly cleaning it, don't grease it etc should just be lean
If that fails it new starter time, not the cheapest thing though but you don't really want one to jam on you as it can cause all sorts of problems
Tim
