Author Topic: remote key coding  (Read 2739 times)
Offline nadlad
  • Building Surveyor MRICS
remote key coding
« on: 26 January 2006, 14:27 »
just got a spare key any idea show to code it in apart from main dealers
i only have one other main key which i use i dont have a valet key or anything!
<<<Big Build Thread>>>
Offline Rhyso
Re: remote key coding
« Reply #1 on: 26 January 2006, 14:29 »
need someone with VAG COM  - ideally a local independent VW garage or even a mate who got it.
Don't think there is any other way I'm afraid  :sad:
Offline nadlad
« Reply #2 on: 26 January 2006, 14:33 »
so u know these instructions that i got given
" Place one key in the ignition and switch it on, (engine not running). Take a
second key and turn the door lock on the outside driver door handle to the
unlock position and hold it until you hear three beeps. Then release the key
and press the lock button on each remote to be programmed. There will be a
beep to confirm each remote. Once done, hold the lock in the unlock position
again untill you hear three beeps. Remove the key from the ignition. Your
remotes should now be set. "
are they a load of bo11ocks?
Offline Rhyso
« Reply #3 on: 26 January 2006, 14:38 »
think thats for the alarm and remote locking.
however, for the immobilsier to work the key needs to be properly programmed by VAG COM i belive  :undecided:
Offline nadlad
« Reply #4 on: 26 January 2006, 15:02 »
i just rang vw harrogate they were more worried about where i managed to get a blank key from anyway he said if u get teh key cut then they code it in for £21.75 + VAT which is for alarm, central locking, immobiliser and ignition key so seems like ill have to take it there. what do u think
Offline Rhyso
« Reply #5 on: 26 January 2006, 15:06 »
the biggest headache you'll get is getting the key cut mind - i don't know of any places that will touch the flip keys  :undecided:
Price sounds reasonable mind but I've never had to get a key coded so not entirely sure
Offline nadlad
« Reply #6 on: 26 January 2006, 15:46 »
ave rang 3 or 4 local general key cutters they said u wont have a problem if ure just wanting the blade cut as they have laser cutting cost between 4- 6 pounds
Offline Rhyso
« Reply #7 on: 26 January 2006, 15:50 »
job's a good one then mate  :smiley:
Offline Phil_M
« Reply #8 on: 26 January 2006, 23:38 »
Thats a good price, Just booked mine in at local stealers and they want £65 :angry:
GOLF 1.9T AGU TD05H 18G
http://smg.photobucket.com/albums/v218/pipmann30/GOLF%20GTI%20%20TURBO/?albumview=slideshow
Front wheel drive monster 0-60mph in under 5sec 0-100mph in 10sec
Offline nadlad
« Reply #9 on: 27 January 2006, 11:53 »
philb best thing to do is get one of ebay get it laser cut cost me £5.00 and then take it to stealers and say that the code does not work they will charge u 21.95 plus VAT i think its standard charge with VW  and it takes a 1hr waiting time to get the code from main main VW and then they program it in jobs a good un
