Author Topic: Inlet manifold problem (urgent)  (Read 1189 times)
Offline Si
« on: 13 January 2006, 16:22 »
To remove the inlet manifold on a 1.6 Driver do i need to remove the exhaust manifold aswell? i can get to two bolts either end of inlet manifold but i think the other 4 are underneath but exhaust is in way?  :undecided:
Help... my car is now in bits! and its getting dark!  :cry:
I LOVE THE SOUND OF CARBS IN THE MORNING
Offline takethefifth
Re: Inlet manifold problem (urgent)
« Reply #1 on: 13 January 2006, 16:38 »
All i can find is in the haynes for "carburettor engins 1.6/1.8"...
inlet manifold removal
1. remove the carb
2. disconenct preheater wire at inline connector
3. drain coolant & remove hoses
4. disconnect vacuum hoses where necesary
5. where applicable disconnect stay rod betweent the base of the manifold and the crankcase
6. undo the manifold retaining nuts and bolts from there locations...
Useful eh? Gotta love the haynes....  :smiley:
the pic shows 4 bolts, 2 either side of the second spark plug and 2 allen bolts on the outsides of the manifold. Doesn;t say anything about removing the exhaust manifold.
Or have i got the wrong engine?!?  :laugh:
Good luck!  :smiley:
« Reply #2 on: 13 January 2006, 16:54 »
No you don't, but the 2nd & 3rd bolts from the right are a complete nighmare.  I used a long thin extension bit holder and a small ratchet spanner.  Even then it took alot of fumbling around to get it in there.  To be honest I'm not sure if it would be any more difficult to do it at night :grin:
Check my 2e2 FAQ post in the garage section for a complete start to finish guide :)
Offline Si
« Reply #3 on: 13 January 2006, 18:09 »
Just come in for a break...
aaaaaaaaaaaaarrrrrrrrrrrrrrrrrrrrggggggggggggggggg!!!!!!!!!!!!!!!!!!!!1
This is doing my fuc@ing head in!
Rubjonny you were right, it is a nightmare!!!
Dont try this at home kids!  :angry:
« Reply #4 on: 13 January 2006, 18:18 »
Aye take a break from it, best thing to do.  Thats what I did before I beat the sh!t out of it with a lump hammer :grin:
The next time you do it it'll be a piece of piss :)
