Author Topic: rear arches  (Read 1644 times)
Offline jasonpi
rear arches
« on: 09 January 2006, 11:28 »
got some work done to the car yesterday and noticed that on both rear arches the inner ones are rusted and will need to fabricate new ones. has anyone experienced this and is it time consuming?
i know that rear arches alone can be bought from vw at relatively cheap prices and welded on but as for the inners what do i do?
Offline Gambit
Re: rear arches
« Reply #1 on: 09 January 2006, 13:23 »
when i found my inner arch round the fuel flap was badly rotten (i put my hand thru it!) on my old 16v.  i promptly patched it with biscuit tin/grip fill and a load of underseal then sold it
if its badly rotten then it will cost an arm & a leg to fix
Offline tobz.
Re: rear arches
« Reply #2 on: 09 January 2006, 14:13 »
Note to self.......never buy a car from gambit!!!
Would it be possible to remove the inner arch from another car at a scrappy if they're not available/too expensive new???
You got any pics of your dad's split ?
Offline Gambit
Re: rear arches
« Reply #3 on: 09 January 2006, 19:55 »
again its just a pig of a job because of the rear strut towers etc. im not sure if you can even buy new inner rear arches
* buying tip*
if you ever go to buy a mk2, hand up & under the rear driverside arch around fuel flap & give it a good & prod ;)
Offline jasonpi
Re: rear arches
« Reply #4 on: 10 January 2006, 09:32 »
the only place it seems to be rotten is when it joins the outer arch which i will be replacing and it is quite easy to access?!
Offline Gambit
Re: rear arches
« Reply #5 on: 10 January 2006, 13:22 »
you should remove the rear door card and drop the seat and that'll give you a better idea of the rust
Offline Simpson
  • one day il learn
Re: rear arches
« Reply #6 on: 10 January 2006, 18:32 »
I had a lot of rot on the nearside in this area due to acident damage, my neighbour repaired it for me as i wouldnt trust myself to do it. bug job but if you know what you are doing well worth it if the rest of the car is clean. I went to the scrappy and cut a mint panel and as much of the inner arch as i could get and he slid it over the rotten panel, well ground off rust first of course, hope this helps  :smiley:
i must buy a new car!
Offline jasonpi
Re: rear arches
« Reply #7 on: 12 January 2006, 01:17 »
i did :smiley: when my G/F gets out of hospital i will post some pics
