Author Topic: mk 2 computer!!!!  (Read 1387 times)
Offline bulk66
  • Im broke an it aint a joke!!!!
mk 2 computer!!!!
« on: 07 January 2006, 21:15 »
Hi all can any one tell me how many miles i need to do befor the mpg part of the trip computer starts to work. I do around 5 miles a day to work and it never gets any lower than 86 mpg either my car is running on thin air or some thing is a miss any help would be great. Oh my car is a 91 8valve if that makes any difference cheers...... :smiley:
Offline bulk66
Re: mk 2 computer!!!!
« Reply #1 on: 07 January 2006, 21:19 »
Oh can any one tell me which fuse is for the computer as i might pull it out and see if that resets it .........
Offline ...joe
« Reply #2 on: 07 January 2006, 21:33 »
if your mpg is reading that high its normally due to a spilt in the vacuum hose that feed the  clocks. check for a hose going through the bulk head and that it is intact. have your clocks ever been taken out?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline bulk66
« Reply #3 on: 07 January 2006, 21:40 »
Ive never taken the clocks out but the guy who had it befor me used to show it so they could of been out at some point. Have you got any more info or a picture about this hose cheers mate.... :smiley:
Offline ...joe
« Reply #4 on: 07 January 2006, 21:44 »
err not right now, think it comes off the inlet manifold and goes through the bulkhead to the back of the clocks. basiclly it  could either be split or more than likely if the clocks have been out, the hose wasn't put back on. it can pop off if you don't know its there when you pull the clocks out. so if it was removed by accident it might not have been put back.
just go round the top of the inlet manifold and look for a bit of tube going through to the back of the dash
Offline bulk66
« Reply #5 on: 07 January 2006, 21:48 »
Ah cheers Joe............ :grin:
illumin
« Reply #6 on: 07 January 2006, 22:24 »
Heres a link that I was given a couple of weeks back - The braided hose in front of the blue arrow is the MFA one. Mine was disconnected due to a split hose, sent the MFA mad..............
http://www.clubgti.com/forum/forum_posts.asp?TID=94620
Offline Mr Blue
« Reply #7 on: 07 January 2006, 23:58 »
if the hose has come off from the back of the clock the reading will show '99.9' mpg am i right?
look at the inlet manifold and there is a 'T' connector with a vacume hose on each end. Also check the airbox pipes
sounds like a split hose
 :smiley:
Offline bulk66
« Reply #8 on: 08 January 2006, 00:51 »
I have a drilled air box should i of done any thing with the 2 breather pipes that fit on to it ? :smiley:
Offline ...joe
« Reply #9 on: 08 January 2006, 10:33 »
^^ nah that will be fine. actually i agree with blue, if the hose is disconnected it'll read 99.9, so its  more likely to be a bit of crappy hose!
