Author Topic: Mk2 Hub conversions - Questions regarding 5 studs  (Read 3139 times)
Offline Sega_Boy
« on: 06 January 2006, 19:44 »
Right folks, not really knowing an awaful lot about the technical side of the process, but im surious.
What is involved?
I really fancy a certain set of adui rim's on my mk2, and they only do them in 5 stud, PCD 5 X 100, which i'm assuming is the same as mk3 golfs etc.
What's needed to get 5 stud rims, on my 4 stud mk2 driver?
Is there an easy way to do it with adapotrs, or would I need a total mk3 set-up swopped over?
Ta folks. :smiley:
Offline ...joe
Re: Mk2 Hub conversions - Questions regarding 5 studs
« Reply #1 on: 06 January 2006, 22:42 »
either way to be honest, adaptors is easier but might make the rims stick out too far, plus if you went for a hub swap its a good chance to upgrade brakes?
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Sega_Boy
« Reply #2 on: 07 January 2006, 00:58 »
Not sure, atm full braking set-up is off in the future along with an engine upgrade, but where can you get the 4 bolt to 5 bolt adapotrs from then?
What kinda offset would i need to run to compensate for them etc?
Offline roverspeed
« Reply #3 on: 07 January 2006, 01:43 »
i have seen a few adapters going about on e bay before, but taking them 5x 130, you might fight it hard to find ones to 5x100, i imagine that because the holes were at the same diameter as the bolts holding on the adapter, but i dunno, i am sure if its possible your cheapest and easiest option would to get a engineering firm to whip so up for you on a lathe, using probably steel, i dunno if aluminium would be too soft or not???
Offline Sega_Boy
« Reply #4 on: 07 January 2006, 02:21 »
I guess just have to keep my eyes open for a mk3 set-up then, safer that way.
Right then, what do I need!!! :grin:
Give me the list, lol!
Offline Gambit
« Reply #5 on: 07 January 2006, 17:21 »
tbh id just find a set of 4 stud wheels you like. more hassle than its worth
Offline HARDCOR3
« Reply #6 on: 07 January 2006, 17:24 »
are you all talking crap???, Venom motorsport do 4x100 to 5x 100 adaptors, they'll set ya back £150 complete for a set of 4...... :wink:
Easy as that :wink:
Offline Gambit
« Reply #7 on: 07 January 2006, 17:28 »
aye but increase your offset by +15 / +20mm as already mentioned or can you not read?
so then you need to find 5 stud wheels with et50/55 which aint easy!
Offline HARDCOR3
« Reply #8 on: 07 January 2006, 17:40 »
where above does it mention offset???, i must be blind...... :cool: (where's mi white stick)
Offline Gambit
« Reply #9 on: 07 January 2006, 17:51 »
very 1st reply down
"either way to be honest, adaptors is easier but might make the rims stick out too far"
which is what i said in laymans terms!
