Author Topic: any ideas about this lot  (Read 7198 times)
Offline vr4000d
Re: any ideas about this lot
« Reply #10 on: 05 January 2006, 19:12 »
what make/model are they?
unless they are designed to run freeair then stick them in a box
Offline Lewy
« Reply #11 on: 06 January 2006, 00:03 »
1 15" and 2 8 inchers in the boot....
AAAAARRRRRRGGHH.......don't do it, they'll cancel each other out, and apart from that, sound sh1t!
Get the biggest size you can up front (16 or 17cm) and power them with a decent 2ch amp, and then either a single 10" or single 12" in a sealed box (depending on what kind of music you listen too) powered by a mono amp, therefore sending a complete low frequency signal to the sub. Try not to read too much into the whole MAX WATTS figure as they are more than likely to be inaccurate of the amplifiers power. My Genesis profile 4 is only 4x75w RMS, but when bridged powers a set of Focals a treat.
With the set-up you've mentioned I would bung 3 of the 8" subs in a sealed box being run off of the big amp, and run the front set-up of mid-range and tweeters off of the smaller amp. I personally wouldn't bother with the other set of mid-range speakers as you can mess up the sound stage something rotten.
Lewy
Offline golfpro
  • If in doubt, pay someone else to do it!
« Reply #12 on: 06 January 2006, 08:51 »
got to agree with lewy here. Not a fan of rear speakers as they bugger up the sound stage. 2 or 3 of the 8s in the boot off the big amp and the front speakers off the smaller one, job done!
thats the best mk3 ive seen..ever! its just clean and subtle.. :cool:
Offline theviper
« Reply #13 on: 06 January 2006, 09:05 »
so i would need to take the rear mids out too then  can i put the amps under the rear seat's or with they overheat ????
pete :evil:
Offline golfpro
« Reply #14 on: 06 January 2006, 09:09 »
Leav them in but just dont wire them up. If your having to make a box for the subs anyway why not make a little something for the amps too?
Offline j_s
« Reply #15 on: 06 January 2006, 13:46 »
I would consider a 4 channel amp for the fronts if going for components. Reason being you can bridge the channels for more power to start with and then gives you the option for going active (directly powering the mids seperate from the tweeters with the correct frequencies).
And as Lewy said, don't run a 15 with a couple of 8s, stick with the same model and size subs if going for more than 1.
James
Offline theviper
« Reply #16 on: 07 January 2006, 07:50 »
right then i will have the the 6.5 and uprated front and a tweeters in the front and 3x 8's in a box  now what size MDF to use  12mm for the front ?? and 18mm for the box ?? what is the carpet stuff that covers it called do i need to get it for a radio shop or a place like motorwold ???
pete :evil:
Offline golfpro
« Reply #17 on: 07 January 2006, 09:00 »
think its called carpet tbh  :tongue: han from here works for motor world, im sure she will be able to help ya but i would think ul find some there. look on ebay tho, might find something thatl do the job cheapest there
Offline theviper
« Reply #18 on: 07 January 2006, 10:31 »
just drawing some plans for the box  do i make a single box for the 2 sub's ??? do i make 2 box's and glue them together to make one box ???  or do i make two box's to go in the gap between the wheel arch and boot ???  and would i be right in saying the subs need to face the rear of the car so the sound hit the back and the rolls forward if you know what i mean lol
Pete  :evil:
Offline vr4000d
« Reply #19 on: 07 January 2006, 11:25 »
why only run 3 subs? you have a 4ch amp if it is 2ohm stable run 2 subs off each channel:) then you can run 2 small boxes.
i would only use 12mm for box really as 8`s arent going to flex it.
