Author Topic: Supercharged 'Driver'  (Read 1972 times)
Offline Si
« on: 30 December 2005, 21:31 »
Ok, sounds crazy but ive been toying with the idea for a while now.
If anybody has ever looked at a series 25 1.6 Camper Van engine then they may know what im gonna talk about?!...
They have got a Heater blower attached to the Alternator, (looks like Supercharger). Anyway, it bolts to the Alternator fixing bolts and the middle shaft drives the blower / fan.
Now, ive been thinking i could fit this blower to my 1.6 Driver Alternator and direct the air flow to airfilter? trouble is the Alternator shaft on Golf isnt long enough as it has a spacer to step pulley away from Timing belt cover.
Questions i need answering are---
1) What VW Alternator has a very long shaft that could be used?
2) If i got it to fit, it would be blowing a huge ammount of air to intake on idle, aswell as driving, how could i create a valve to shut off air on idle?
3) It would underfuel loads, how could i get more fuel to Carb to compensate air / fuel ratio?
4) Would i need non-return valves on fuel lines to stop blow back?
I will take photos tommorow. :smiley:
I LOVE THE SOUND OF CARBS IN THE MORNING
Offline Si
Re: Supercharged 'Driver'
« Reply #1 on: 31 December 2005, 17:50 »
Ok, me and the old man have been rattling our heads together....
Worked out everything i need to do it except an Alternator with a shaft long enough (lot of work fabricating one).
Any help?  :rolleyes:
Offline The Hoax
« Reply #2 on: 31 December 2005, 18:16 »
Si
I would think that you will be wasting your time as I can't see a heater blower producing anything like enough air to increase power.
Sorry but just my honest opinion.
Offline Si
« Reply #3 on: 31 December 2005, 18:23 »
Wound it up using wizz gun on compressor at 2000rpm, we measured the pressure at 4 psi! AT 2000RPM!!!!
The gun wouldnt fire up anymore revs so couldnt see what it measured at over 2000! but i would imagine it would be more than enough!! Too much if anything!  :rolleyes:
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 02 January 2006, 12:36 »
interesting idea, but how are you going to stop it blowing up the first time you change gear.. there will be no fuel going into the carb for a moment while the blower keeps pumping.
Offline Si
« Reply #5 on: 02 January 2006, 16:28 »
Need to remake a pressure release valve like a waste gate as such.
Also, ive woked out and make a valve operated by choke cable inside car to open / close valve so on idle the valve is closed (blows air into engine bay) and when moving i can open valve (pushing air to intake)!
Still having trouble with it underfuelling and need an alternator with longer shaft.?!  :huh:
Offline takethefifth
« Reply #6 on: 02 January 2006, 17:00 »
You're a crazy crazy man! But damn i wish you luck!  :grin:
Offline Devon Joe
  • Liebe zum ropey Automobil
« Reply #7 on: 02 January 2006, 19:41 »
Or maybe try four of those yeBay 'electric superchargers +250 hp' onto home-made throttle bodies??
Only kiddin!!  :drool:
If only my Volkswagen was as reliable as everyone else's...
Offline Si
« Reply #8 on: 03 January 2006, 19:56 »
Hey, ill try most things once!!  :grin:
Offline Chugadub
« Reply #9 on: 03 January 2006, 22:06 »
^ like he said!
but im in bristol too, if u want a hand messing about or summat just gimme a shout - sounds like a laugh!
 :smiley:
Cant afford a sig.....
