Author Topic: help! stereo only works when i push on key-mk3  (Read 2505 times)
Offline joeyindagolf
« on: 22 December 2005, 20:29 »
my stereo only turns on when i fiddle with the key and push it in a bit??? any ideas i will be runnin a seperate supply if noone can help
Offline Dizzie
  • Make friends with your fast
Re: help! stereo only works when i push on key-mk3
« Reply #1 on: 22 December 2005, 23:08 »
sounds like a dodgy connection somewhere to me. either that or a faulty stereo.
Mk4 Golf 150PD
Offline Dom Mk3
  • Insert wit here
« Reply #2 on: 23 December 2005, 00:04 »
having the key in the ignition will supply an ignition feed to the radio, you don't have to turn it. Sounds fine to me?
Offline silkyballs
  • more tea vicker??
« Reply #3 on: 23 December 2005, 00:12 »
dude best bet is to run a decent permanent live and fuse it at the battery ive done every car ive ever had not always needed but personaly i think its always the the safest route.sounds like it could be the ignition switch??i got one for a mk1 the other week from german and sweedish cost about £4 i think??
http://[img]
Offline vr4000d
« Reply #4 on: 23 December 2005, 07:52 »
as Dom Mk3 said the stereo does only work when key is in. if you mean its tempermental when its in maybe you have a dodgy key or wiring, might be worth putting a permenant live in
