Author Topic: MkII Dash Speaker Removal  (Read 2503 times)
Offline Whysub
« on: 20 December 2005, 15:18 »
How do I remove the dash speakers on my 1991 Mk II? Is there a hidden screw that secures the grills on? DonÂ’t wanrt to damage them by prising them off.
Anyone recommend a direct replacement? Not wanting to spend much-only use the radio to receive traffic reports, but the drivers side speaker sounds awful.
Offline steviem
Re: MkII Dash Speaker Removal
« Reply #1 on: 20 December 2005, 17:57 »
Ok, just have a look at the grill on the driver's side, where it faces you rather than the window, there is a little square of plastic nearer the door, just prise that from the bottom and that will pop off, under that is a screw, undo that, and you can pull the grill away...
If you want to wait, when its light tomorrow, I'll take some pictures and post them up here so you know exactly what to do.
Offline Whysub
« Reply #2 on: 21 December 2005, 15:06 »
Thanks for that-I have seen the little "panel" but didn't want to try and prise it off if it didn't come off!
I have seen how fiddly ikt is to get the speakers out...............
Offline steviem
« Reply #3 on: 22 December 2005, 01:17 »
TBH I just stuck tweeters for my components on the old speakers...sounds gr8 tho...
Offline GTI EDITION (aka LTD)
« Reply #4 on: 22 December 2005, 01:31 »
The only time I've ever had to upgrade some the customer wanted a new windscreen so I replaced them before I fitted the new screen  :cool:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline Dizzie
  • Make friends with your fast
« Reply #5 on: 22 December 2005, 12:34 »
I stuck my tweeters over the old speakers that I murdered too :D
Mk4 Golf 150PD
Offline GolfChick24
« Reply #6 on: 22 December 2005, 16:34 »
removed the stock speakers using a right angled screwdriver  :cool: and replace with new tweeters above.
