Author Topic: WATERLEAK?  (Read 4114 times)
Offline ducatimad
WATERLEAK?
« on: 06 November 2003, 17:48 »
I Have just purchased an absolutely mint golf gti 8 valve, 5 door, H reg with every old mot and service document not even a mark on the drivers seat bolster!  I am lucky!  But it does have one fault that the drivers front footwell and a bit behind drivers seat is damp - any ideas - The car is truly mint and never been welded, crashed or even a trolley dent - I wondered whether there were any common areas of waterleak - it definately seems more prominent in the drivers footwell and seems to seep to the back!
Ducatimad
Blue MK2
Re:WATERLEAK?
« Reply #1 on: 06 November 2003, 17:53 »
Could be water entering by your bonnet pull. The water could be dripping from the bonnet, down the cord and entering the footwell? Happend to a mate of mine. You with me?
Maybe a burst heater matrix? does the heater give out heat?
Leaky sunroof?
« Last Edit: 06 November 2003, 17:54 by Blue MK2 »
Offline ducatimad
Re:WATERLEAK?
« Reply #2 on: 06 November 2003, 17:55 »
defiately not the heater matrix! checked that but will check out the bonnet pull cheers!  I am a total perfectionist so this will be cured! Any other ideas gti people?
Blue MK2
Re:WATERLEAK?
« Reply #3 on: 06 November 2003, 17:59 »
I think VW's are perfectionist cars anyway  :)
Offline ducatimad
Re:WATERLEAK?
« Reply #4 on: 06 November 2003, 18:25 »
I am on my knees and bowing down to your last statement!  gti forever my lord!
Blue MK2
Re:WATERLEAK?
« Reply #5 on: 06 November 2003, 18:34 »
''Thaw shall not drive a ford'' hahaha
Offline Slim Shady
  • Thrash her like a ginger step child
Re:WATERLEAK?
« Reply #6 on: 06 November 2003, 18:42 »
blocked drainage channel in the A post - clean it out with a compressed airline
Offline ducatimad
Re:WATERLEAK?
« Reply #7 on: 06 November 2003, 19:47 »
What a great forum!  I have never been more excited to actually spend time fixing an anoying fault!  fitting a performance modification is great fun because you are sure its going to make you happy!  but run of the mill maintanance just doesn't do it for you normally does it!
Cheers everyone who has sent a message of help!
Offline carloscdt
Re:WATERLEAK?
« Reply #8 on: 07 November 2003, 16:28 »
take off the inside door cover and see
if the membrane is split.
Offline ducatimad
Re:WATERLEAK?
« Reply #9 on: 08 November 2003, 14:01 »
Busy day today! I replaced the drivers door membrane and sealed the bonnet catch gator better although it looked like new!  I also cleaned all the crap in the scuttles by the ecu and by the fan and also cleaned through the sunroof tubes!  hopefully this should cure the problem!  notice that I have followed all you peoples lovely advice! also had a squeaky interior fan so I stripped it down cleaned it with duck oil and reasembled - and its great no squeak!  Also polished and cleaned the car for 4 hours!  This is what weekends should be for!
