Author Topic: oops  (Read 1679 times)
Offline aaand
oops
« on: 13 December 2005, 19:22 »
my mark 2 has had a bad rear smack,    has a crease on the floor pan( near the spare wheel, and drivers door wont shut properly, i know its a right of but  what i want to know is,  is it possible to fix a  writern of car, not money wise i mean structural and that, please   advice needed
Offline Chugadub
Re: oops
« Reply #1 on: 13 December 2005, 19:59 »
 :sad:
oopies
how you manage that?
you gotta think is it worth it, depending on the circumstances it may be easier having new car to play with again.
im not the best to speak but im guessing 'the daddies' (rub, slick etc...) are goin to say u cant tell without looking at it. sounds bad tho...
 :undecided:
Cant afford a sig.....
Offline Mart8V
  • I really should know better by now.....
Re: oops
« Reply #2 on: 13 December 2005, 20:04 »
Don't want to be a merchant of doom, but that sounds pretty terminal.  Is it 3 or 5 door?  If the driver's door won't shut that would indicate further chassis damage (in my totally unprofessional opinion!) and a crease in the floorpan is never good.
Time to break it and start saving!? :cry:
Offline Si
Re: oops
« Reply #3 on: 13 December 2005, 20:05 »
Not good mate!
Mine would be a write off aswell if i went through the insurance!  :cry:
It depends how bad it is, panels are easy to replace, but if the underside of the car is bent it might not pass an MOT or could be unsafe to drive?
When it is damaged is a weak point now.  :sad:
I LOVE THE SOUND OF CARBS IN THE MORNING
Offline Chugadub
Re: oops
« Reply #4 on: 13 December 2005, 20:10 »
Duh yeah just remembered, when my mum had rear end in her Astra apart from wrecked bumper all you could see was tinyweeny crease in boot floor - but that ended up costing £2400 (whole chassis fooked). Which was ok for £14k car on someone elses insurance but for a mk2 golf.... uh oh.
Offline aaand
Re: oops
« Reply #5 on: 13 December 2005, 20:11 »
it is a 3 door, cant really  think about getting another, just  spent  evrything on it  i own to restore it, this is a set back
Offline Si
Re: oops
« Reply #6 on: 13 December 2005, 20:21 »
Why dont you look at buying a dirt cheap 1.3? Then swap every thing over?  :huh:
Offline aaand
Re: oops
« Reply #7 on: 13 December 2005, 20:41 »
dont have the tspace, gonna run it till next mot see how it goes, will replace the rear pannel and bumpers,(and hangers)  its just a hell of a lot of work i guess
Offline Si
Re: oops
« Reply #8 on: 13 December 2005, 20:45 »
I bent my car after i hit a kerb sideways!
Bent wishbone, wheel, strut, bonnet, smashed arch, bumper, and cracked the dash!
Underneath is slightly bent but not that noticable unless you know what your looking for!  :smug:
Offline aaand
Re: oops
« Reply #9 on: 13 December 2005, 20:52 »
is that your car?(the pic) yeah thee seems to be o other sighn of damage, so i will probaly  fix her up,
