Author Topic: MKV INSTALLING SAT NAV MDF2  (Read 2951 times)
Offline ukheman
« on: 10 December 2005, 22:03 »
Golf GT GTI 2005
has anyone got any pictures of the centre console on how to remove the plastic trim so i can remove the old cd player and install the mdf2 system. before i break the plastic trim.
ive tried to search for a step by step instruction guide on how to remove the radio but couldnt find one on the net.
thanks inadvance
« Last Edit: 10 December 2005, 22:06 by ukheman »
Offline Dom Mk3
  • Insert wit here
Re: MKV INSTALLING SAT NAV MDF2
« Reply #1 on: 11 December 2005, 03:27 »
ahh the plastic trim on a mk5... fitted enough phone kits in these now! it clips out, be gentle but firm is my advice. (trust we're talking about the surround of course).
Offline ukheman
« Reply #2 on: 11 December 2005, 09:43 »
yeah the last thing i wanna do is scratch the plastic trim .. so im assuming this just pulls out .. around the centre console. then i can just insert some radio removal tools on either side to slide the old CD player out ..
Offline Dom Mk3
  • Insert wit here
« Reply #3 on: 11 December 2005, 11:08 »
I'll get some detailed instructions when I see my mate at lunch  :smiley:
Offline ukheman
« Reply #4 on: 12 December 2005, 15:21 »
ok cheers mate ... i dont wanna cock it up ...
Offline Dom Mk3
  • Insert wit here
« Reply #5 on: 12 December 2005, 17:16 »
just asked: get a trim tool or something with a wide flat face then go in at the sides against the soft plastic dash. Carefully prise it out, slowly making your way round!
Offline Dizzie
  • Make friends with your fast
« Reply #6 on: 12 December 2005, 17:42 »
most of the middle of the dash comes out as well
you'll need a facia panel to fit a DIN sized radio with is autoleads part number FP-17-03 :)
Mk4 Golf 150PD
Offline ukheman
« Reply #7 on: 12 December 2005, 23:26 »
thanks ! if i damage it can i come to your mate for a refund ?
 :laugh:
Offline Dizzie
« Reply #8 on: 13 December 2005, 00:14 »
nope
Mk4 Golf 150PD
Offline ukheman
« Reply #9 on: 17 December 2005, 10:54 »
sorted only took about 5 mins to get the trims off.. but helps to know where the clips are !
best to take the heater trim off first as the clips fit into the radio trim .. if you just push it up the clips pop out then .. you can just pull the radio trim off..
only 6 screws in total .. didnt take that long .. antenna cable just threaded through back of dash ..
