The garage
Induction Kit question...
Topic: Induction Kit question... (Read 2316 times)
Blue MK2
Guest
04 November 2003, 22:27 »
Is it true that you have to disconnect ur battery for 24hours so that the ECU resets.
The reason to reset it is so that the ECU can adjust to your induction kit?
u wid me?
golfvr6
Guest
Re:Induction Kit question...
04 November 2003, 23:54 »
You do not have to do that at all. The ecu will receive a different signal from the airflow meter, so it will re-adjust automatically.
golfvr6
Guest
I presume yours is a digifant?
Blue MK2
Guest
05 November 2003, 11:23 »
Yeah its a Digifant
free
Guest
06 November 2003, 15:06 »
i fitted a 57i kit to mine a few weeks ago, thats the first ive hurd about it. mine went alot better and run perfect stright away. does it reset the ecu if u disconnect the baty for 24h theo?
Blue MK2
Guest
06 November 2003, 16:14 »
duno thas y im asking coz i read it in another forum
golfvr6
Guest
Reply #6 on:
07 November 2003, 00:15 »
If you do that the ECU should return to factory settings.
The garage
