Poll
Car cost £150, look at the following pictures of the underneath, should I fix it or scrap it?
Yes, weld it up and put it back on the road, too good to scrap?
18 (85.7%)
Scrap it, recover the money spent and look for something better?
3 (14.3%)
Total Members Voted: 21
Author Topic: Fix it or scrap it?  (Read 6104 times)
Offline homer
Re: Fix it or scrap it?
« Reply #30 on: 06 December 2005, 10:15 »
thanks for ur reply u r best off getting rid off it and put the money in to the mk1 mate
Offline richandhazel
« Reply #31 on: 06 December 2005, 10:24 »
Right I've slept on it, not literally lol, and I'm going to re-assess this morning. I've welded up a lot worse in the past and its not going to cost me anything other than time to give it a go............
Offline GTI EDITION (aka LTD)
« Reply #32 on: 06 December 2005, 10:41 »
SACRILEGE !!!! The car looks far too good ( judging from the pictures) to scrap ! IMO . As long as all the rot is cut out and it's welded properly it will be as good as new  ( or even better/stronger if you use thicker metal )    :wink:
I always think it a shame when I see Golfs and other V'Dubs in breakers yards as often when I've looked around them they are often still in serviceable condition, if only someone was willing to spend a little time an effort on them . The trouble is that some people panic thinking their cars had it just because it requires a bit of welding. :cry:
( P.S. Just be carefull of the fuel lines  :nerd: )
« Last Edit: 06 December 2005, 11:04 by GTI EDITION »
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
« Reply #33 on: 06 December 2005, 10:45 »
Spot on, if welded properly (which it will be :wink:), it should be stronger than original.
Looks like I'm going to be dropping the subframe and fuel tank and dusting off the welder. Pictures to follow.........
Better get off this thing and get my a**e in gear :rolleyes:
« Reply #34 on: 06 December 2005, 15:41 »
The latest: subframe and tail pipe now removed so good access. Have chiseled out the worst of the damage, now about to attack with a tool that I have just bought: wire cup in an angle grinder.
Pics just taken, prior to attacking with the angle grinder:-
Subframe removal:-
Damage:-
Offline AudiA8Quattro
« Reply #35 on: 06 December 2005, 15:50 »
Good luck mate, looks like a sh!t of a job.
« Reply #36 on: 06 December 2005, 16:25 »
Cheers, I think I'll need it, I haven't done any welding for about 10 years so I'm going to have to teach myself all over again :rolleyes:
« Reply #37 on: 06 December 2005, 16:49 »
Good luck, i still don't agree that section will be stronger, but its up to you..
Offline Neaty
« Reply #38 on: 06 December 2005, 16:53 »
^^^ well its going to me stronger than it is now!  :grin:
« Reply #39 on: 06 December 2005, 16:59 »
True  :laugh:
