Author Topic: Problem with swithed power supply stereo in Mk3  (Read 1910 times)
Offline LBManiac
« on: 16 November 2005, 15:24 »
ok... I installed a sony CD player in my golf and It works but it doesn't switch off properly.
It used to go on when the key was pushed in slightly (like a switch was triggered when you put key in).
I had stereo up (too) loud once and it cut out...  But it goes on when key is turned to ignition position in a certain place.  When key is removed stereo goes off straight away and loses memory after 5mins or so(no power at all going to radio).
I think my latter problem of having to put key in a certain position to make it go on is because the head unit took too much power (to power 220W 6x9s without amp  :shocked:)through the switched power supply (thin wire) and might have burnt out something.
But the problem of the stereo not having power trickle when car is off is a mystery, all wires and fuses are in correct place.
One thing I did discover is when I remove fuse from fusebox for stereo it makes the beeping noise to remove the front(never did before).
LBManiac
'92 Red VW Golf 1.4 Mk3
Offline Dom Mk3
  • Insert wit here
Re: Problem with swithed power supply stereo in Mk3
« Reply #1 on: 16 November 2005, 22:40 »
Your power and ignition are most likely the wrong way around. That'll be the red and yellow on the back of the headunit.
