Author Topic: Diverter Valve Replacement  (Read 2047 times)
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« on: 15 November 2005, 10:09 »
I've just bought a brand new Forge D.V., & have noticed that the top 'stem' on it where the vacuum hose attaches, is a bit thicker than the standard one.
Now, my question is..... Does my current hose keep splitting when I try & slide it onto the D.V. because of it's age (5 years - ie. gone brittle), or is it just because the pipe is too thin, & even a brand new one won't fit.
Do I need to get a vacuum hose fabricated?
Cheers,
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline topher
  • Administrator
  • fully functioning
Re: Diverter Valve Replacement
« Reply #1 on: 15 November 2005, 10:14 »
they get brittle with age and crack, you may find its even cracked under the braiding somewhere, effectively leaving your DV constantly open and loosing most of the boost. a new hose will slide on, although it is a tighter fit than the standard dv.
« Reply #2 on: 15 November 2005, 10:57 »
That was quick! Cheers for that. Will pop into the Stealers lunchtime!
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 15 November 2005, 20:21 »
no probs matey, exact same thing happened to mine last year.
Offline GazB
  • Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
« Reply #4 on: 15 November 2005, 20:35 »
Yeah I used my standard one with no probs, stick a tiny bit of washing up liqud on the DV and it will help the pipe slide on :smiley: :smiley:
« Reply #5 on: 16 November 2005, 11:49 »
Cheers for the swift responses, chaps.
Forge were kind enough to send me some silicon hose F.O.C., so have used this.  It's not braided though, so not sure how long it will last, especially with the 'upped boost'! :laugh: (Have got enough for a couple of spares, though). :cool:
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 16 November 2005, 13:02 »
the braiding is just there to disperse heat away from the rubber (thats what makes it go brittle eventually), you dont get that problem with silicon hoses so no worries :cool:
« Reply #7 on: 16 November 2005, 13:13 »
Schweet. :smiley:
