Author Topic: Ignition problems  (Read 3976 times)
Offline crouchy
Ignition problems
« on: 01 November 2003, 14:32 »
I have got a mk3 golf gti 8v untill today the car was running fine. When i went to start it this morning the engine turned over but the car didnt start, I have check the HT lead which is fine, the Dizzy cap is fine and the rotary arm is also fine but i am getting no spark from any of the leads could this be that the coil has gone or could it be that the immoboliser has gone. The car has got power going to the coil but i am geting nothink out. ANY IDEAS ? ???
golfvr6
Re:Ignition problems
« Reply #1 on: 01 November 2003, 23:58 »
I think if the immobiliser has gone then there will be no power to the coil (i might be wrong). I would change the coil.
Offline albo
« Reply #2 on: 04 November 2003, 10:08 »
Freeky - exactly the same thing happened to mine yesterday.  I came on here to search for the answer. :-[
Did you find out whether it is the coil?  In my case I just pulled up in a car park, switched the engine off.  Then 2 mins later went to start it again and there was no spark.
My car doesn't have an immobiliser.  Is there anything else it can be?  The dizzy, rotor, leads and plugs are all in good nick.
Albo
golfvr6
« Reply #3 on: 04 November 2003, 10:11 »
Test for a spark from the coil to distributor, then for a spark from the leads. Could be a loose connection on the coil.
Offline Scirocco2ltr
« Reply #4 on: 04 November 2003, 16:12 »
If it was the immobilser the car would not turn over.
I agree with golfvr6, check the coil  :P
Scirocco Scala 2ltr 8v Gti
Offline Cupra Turbo
« Reply #5 on: 09 November 2003, 23:39 »
If it was the coil the car wouldnt turn over.
I have a similar problem... mines now in the garage for a week!  ::)
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=38
Modified Golf GTI, 130Bhp(est), All Smoked Plus Quad Headl
Offline albo
« Reply #6 on: 10 November 2003, 08:55 »
On mine it was the coil amplifier (available as a seperate part within the coil) - now fixed ?40 for the part.
Albo
golfvr6
« Reply #7 on: 10 November 2003, 14:49 »
Whats the coil got to do with the engine turning over on the starter?
Offline Cupra Turbo
« Reply #8 on: 10 November 2003, 22:17 »
Cos its part of the HT circuit.
golfvr6
« Reply #9 on: 10 November 2003, 23:57 »
Indeed, but the engine will still turn over on the starter.
