Author Topic: Ignition problems  (Read 3977 times)
Offline Cupra Turbo
Re:Ignition problems
« Reply #10 on: 11 November 2003, 23:45 »
Not according to my local VW garage.
ur probably right, those muppets dont know anything...  :D
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=38
Modified Golf GTI, 130Bhp(est), All Smoked Plus Quad Headl
golfvr6
« Reply #11 on: 12 November 2003, 10:41 »
Yep, the starter is connected directly to the battery  :D vw service people are muppets!
Offline Cupra Turbo
« Reply #12 on: 12 November 2003, 23:45 »
Yep, Gonzo and Kermit are at my local VW
Offline tianaroja
« Reply #13 on: 16 November 2003, 17:10 »
100% this is the coil I changed it on mine ?57 and all will be fine!
Offline gti_mk3
Re: Ignition problems
« Reply #14 on: 04 November 2004, 23:01 »
I have the same problem and have VAG COM diagnostic tool. (have already tried plug leads, dizzy etc, and swapped coil with another that I know works)
The VAG COM arrived last week and reads fault code - Immobiliser Implausible signal...??
Had the immobiliser checked by a specialist, nothing wrong with it. He did say however that often there can be a problem with the chip in the ignition key that in turn deactivates the immobiliser ???
So, took the fascia off around the ignition barrel and there is a plastic collar with a thick black wire leading off it into the loom. It looks like some sort of device that would read from the key when placed in the barrel....
Have read before that people have renewed ignition switches on this forum before and the problem has been solved.. can anyone else help on this.?
