Author Topic: driveshaft bolts  (Read 3356 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
driveshaft bolts
« on: 08 November 2005, 19:29 »
right i need tips on getitn these driveshaft bolts out as all of them seem to be rounded off
just my luck
but i need the driveshafts out to replace them
as they are vr6 shafts and i need to put my gti ones in
mole grips wont work either
Offline Mr Blue
Re: driveshaft bolts
« Reply #1 on: 08 November 2005, 20:20 »
First soak it with wd40 then wack a splined socket slightly smaller over the bolt and yank it off   :cool: (got that tip off VR6)
if that wont work then get yourself down the gym sweet'art :laugh:
« Last Edit: 08 November 2005, 20:21 by Blue »
Offline ...joe
« Reply #2 on: 08 November 2005, 23:05 »
cut them off and buy new ones.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Agreeable Slick
  • Unit
« Reply #3 on: 08 November 2005, 23:14 »
sure your using the right tool?? Sometimes they are not hex bolts.
Offline VR6_ROB
« Reply #4 on: 09 November 2005, 17:56 »
any1 got a pic of the toll i shud use because surely all the bolts cant be rounded off
but its the only one that fits feels tight when i put it in the bolt
once i start to try undo the bolt it just turns
Offline ...joe
« Reply #5 on: 09 November 2005, 18:36 »
its a torx bit tisn't it?
  • Unit
« Reply #6 on: 09 November 2005, 18:38 »
mine were torx heads, some are hex heads, i have also heard of some of them being Star heads.
I think the majority of them are torx heads though so try using some of them first.
Offline ...joe
« Reply #7 on: 09 November 2005, 18:39 »
but bear in mind if you've had a go with an allen key you've probably f**ked them up anyway....
Offline VR6_ROB
« Reply #8 on: 09 November 2005, 18:56 »
i aint used a alan key
used a torx bit i think
sort of like a star
but the bolt looks like it has more little points on it
Offline Si
« Reply #9 on: 09 November 2005, 18:57 »
I got a funny feeling mine are allen bolts, not torx?!  :undecided:
I LOVE THE SOUND OF CARBS IN THE MORNING
