Author Topic: Water Problems...  (Read 4007 times)
Fielder5757
Water Problems...
« on: 07 November 2005, 13:55 »
Well, It looks like my heater matrix has gone (Wet floor mats and no heat) But after checking the engine bay there also seems to be water leaking from the big fat hose that goes from the block to the rad. It seems to be leaking from the connector to the Rad. I ordered a new heater matrix off of e-bay but im not sure about the leak in the engine bay. Any ideas?
Offline Daz...
Re: Water Problems...
« Reply #1 on: 07 November 2005, 14:03 »
take the hose off the rad so you can see where it is leaking from...if it's the hose then that's nice and cheap for you...if it's the radiator then that's not so cheap..  :sad:
oh, I got a new hose for mine for £5.50 +VAT from GSF, I know it's slightly different for yours but the price should be about the same  :wink:
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
Fielder5757
« Reply #2 on: 07 November 2005, 14:04 »
Hmmmm the leaks from the block end not the rad end, So its either the hose or....the block??   :huh:
really hope it is the hose, Not the right month to be replacing expencive bits!
Offline Daz...
« Reply #3 on: 07 November 2005, 14:05 »
If it's that end then it should be the hose mate  :smiley:
Fielder5757
« Reply #4 on: 07 November 2005, 14:10 »
yay  :smiley: easy to fix....unless its the switch that seems to be there, or any of that junk.
Fielder5757
« Reply #5 on: 07 November 2005, 14:24 »
 :cry: :cry: :cry:
Doesnt look like its the hose, Water seems to be dripping from a switch, If you look at the below image (its an old one) you can see the thicker hose comming off the rad going towards three switches (two on top, one under) The water seems to be comming from under that uni. Thinking possibly somthing has gone inside there, a seal maybe???
Offline Mr Blue
« Reply #6 on: 07 November 2005, 14:38 »
cracked water flange mate. common. few quid from vw. make sure they give you a new 'o' ring too :smiley:
btw radiators are only 35 quid. well mine was from a local radiator company :rolleyes:
Offline Mr Blue
« Reply #7 on: 07 November 2005, 14:41 »
http://cgi.ebay.co.uk/VW-GOLF-MK2-WATER-FLANGE-102_W0QQitemZ4587151755QQcategoryZ9889QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
 :wink:
you sure that its the matrix thats blown? whats the water level like? Someone i know changed the matrix when it was a leak from the engine bay :laugh:
« Last Edit: 07 November 2005, 14:47 by Blue »
Fielder5757
« Reply #8 on: 07 November 2005, 15:28 »
Just baught A new flange and Orings from GSF...felt like a right wally asking for a new flange, girl behind the counter gave me a funny look as i tried to keep a straight face  :grin:
Offline Daz...
« Reply #9 on: 07 November 2005, 15:29 »
 :grin: :laugh: :grin:
