Author Topic: Poping noise  (Read 2572 times)
Offline 1 Lp
Poping noise
« on: 02 November 2005, 16:43 »
Installed an amp and sub into a golf. Problem is every time u change track, or increase the volume from 0 you hear a loud 'pop' coming from the subs. I confused to what the problem could be?? ne ideas?
VWs are like women, they need love care and attention
Offline Bazzer
Re: Poping noise
« Reply #1 on: 02 November 2005, 19:11 »
If it's happening when you press a button, it *could* be the contacts on the back of the faceplate (I'm assuming you've got a face-off headunit here). Try just pressing the front panel, see if it does it then. If yes, clean the contacts up.
Could also be the connections at the back being moved slightly when you press something, so check they're all insulated well...
Other than that, it could be electrical noise generated inside the headunit and there's not a lot you could do about it.
What headunit / amp is it?  :smiley:
Bazzer
Judderi
Re: Poping noise
« Reply #2 on: 08 November 2005, 15:15 »
Prob y head unit. Sell it on ebay and buy a decent one!
