Author Topic: New Thread re Cutting Out  (Read 2662 times)
Offline RossJames
« on: 30 October 2003, 08:41 »
Having read all the threas about Mark3's cutting out at random moments I was wondering if you would recommend changing the ECU mentioned on my car. It only has a problem with cutting out when starting from cold ?
Go out in the morning starts first time touch the accelerator and the revs dive and it cuts out. Take about 5 minutes of idling with the foot on the pedal to keep it going.
I have looked at the service history and so far it has had new starter, rortar arm,  throttle and butterfly cleaned, and new temp sender relay fitted.
Should I change the Relay mentioned in the other thread and if so what position does it go in the fuse box as the Haye's manual does not mention it  ???
Sorry to go over old ground but just want to get this sorted right !
golfvr6
Re:New Thread re Cutting Out
« Reply #1 on: 31 October 2003, 13:08 »
Change the ecu and fuel pump relay, that seems to work for everyone else.
Offline Cupra Turbo
« Reply #2 on: 31 October 2003, 23:54 »
I have a similar problem.. i have a thread about it sumwhere ...
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=38
Modified Golf GTI, 130Bhp(est), All Smoked Plus Quad Headl
bjd
« Reply #3 on: 01 November 2003, 15:18 »
Hi,
I had this problem.
To cut to the chase, i had my throttle valve/housing cleaned, and the ECU reset.
Problem solved.
