Author Topic: **HOW LONG TO FIT A WATER PUMP PLZ**  (Read 2268 times)
Offline golf gti 16valve
« on: 26 October 2005, 16:11 »
hi ppl i was jus wondering if u could say on average how long it would take to fit a new water pump on myy 88 golf 16v?? and wot damage would it do if i drove it for a while, as its still making a noise as the bearings av gone
Offline Daz...
Re: **HOW LONG TO FIT A WATER PUMP PLZ**
« Reply #1 on: 26 October 2005, 16:14 »
if its anything like mine then it'l take an age...one of the bolts has been rounded off in the past and i can't get the thing off!! if it wasn't rounded off it wouldn't take long tho...depends if you got power steering or not..without it would be a piece of p!ss...prob an hour...counting tidying up afterwards  :wink:
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
Sugar79
« Reply #2 on: 26 October 2005, 16:15 »
i would say about 2hours.. and nooooooooo dont drive it if its overheating  :shocked:
« Reply #3 on: 26 October 2005, 16:16 »
lol nasty, no it doesnt have power steering luckily lol!! is it quite straight foward??
« Reply #4 on: 26 October 2005, 16:18 »
its not over heating just noisey, should this be ok??
Offline Agreeable Slick
  • Unit
« Reply #5 on: 26 October 2005, 16:22 »
I wouldn't drive it, if the bearings are on the way out it is always going to risk blowing at the completely wrong moment and screwing your engine up.
Replacing a water pump should be fairly straight forward, just drain the system, remove the 3 bolts (i think) that hold it in then slot it out from under the car. Again just reverse to get it back in. Although i would personally allow myself about 3 hours to do it in, just so i was sure that it was all correct and i didn't feel like i needed to rush.
Offline Daz...
« Reply #6 on: 26 October 2005, 16:29 »
definatly don't drive it if it's noisy, sure to let go when your stuck in traffic  :rolleyes:
you will also have to swap the pully over and the bottom hose connector...think that holds a thermostat  :undecided:
« Reply #7 on: 26 October 2005, 16:35 »
ok nice one peeps, do i have to remove the cambelt though or not??? im going to attempt it tonight!!
Offline Daz...
« Reply #8 on: 26 October 2005, 16:37 »
Nooooo!!
It runs off the fan belt / drive belt whatever you want to call it...  :wink:
  • Unit
« Reply #9 on: 26 October 2005, 16:38 »
you will need to TDC it though, just as a precaution.
