Author Topic: Vw golf mk4 speaker help?  (Read 39274 times)
Offline gyazg7
« on: 24 July 2026, 10:11 »
Hey guys, new to this forum I hope you can help me out!
Basically I have a MK4 golf 2002.
Looking to buy some new speakers, subwoofer and and amp
I'm a total beginner at this sort of stuff... I'm more of a bass junky in all honesty aswell as nice crisp sound!
What sort of watts am I looking at that'll make the music in my car good?
A friend suggested getting a 1500watt sub and 1000watt amp with 700watt speakers.
What's your answer to this?
Any advice and suggestions would be fantastic!
Offline Nino
  • Insta - F6UGA
Re: Vw golf mk4 speaker help?
« Reply #1 on: 24 July 2026, 15:12 »
This is right up my street. I've installed quite a few systems over the years, including a full custom install in my Mk4 R32, and it sounded fantastic.
The biggest piece of advice I can give you is don't get hung up on wattage. A lot of people see huge power numbers and assume it's going to sound amazing, but that's really not how car audio works.
Your first priority should be a good quality head unit. Personally I'd stick with Alpine, Pioneer or Kenwood. I'd avoid the cheap Android units unless you're spending decent money on one, as the audio quality is generally nowhere near as good.
If your budget allows it, I'd also strongly recommend running your front speakers from a dedicated 4-channel amplifier rather than relying on the head unit's built-in amp. In my R32 I ran Focal 165AS components front and rear from a Kenwood 4-channel amp, and the difference was night and day. The speakers played louder, cleaner and with far more control than they ever did from the head unit alone. It's difficult to describe until you've heard it.
As for your mate recommending a 1500W sub, 1000W amp and 700W speakers... I'd honestly ignore the wattage figures. They're largely meaningless unless you're talking about RMS power, impedance (ohms), sensitivity and matching the speakers to the amplifier correctly. A well-matched 300W RMS setup can sound miles better than a badly matched "1500W" setup.
The first thing I'd ask is:
* What's your budget?
* Do you want a stealth install or don't mind losing some boot space?
* Are you after sound quality with a bit of punch, or are you trying to shake the windows?
For reference, I'm now in my 40s so my tastes have changed a bit! In my Mk6 GTI I'm running:
* Alpine iLX-705D head unit
* Focal IFVW front components
* MTX Thunder TR8PT active sub
It's not earth-shattering, but it gives me lovely crisp sound with enough bass to put a smile on my face without rattling the whole neighbourhood.
I actually wrote a fairly detailed guide on choosing a head unit over on the Mk6 section if you're interested:
https://www.golfgtiforum.co.uk/index.php?topic=290235.0
If you let us know your budget, I'm more than happy to recommend a complete setup that'll give you the best bang for your buck.
« Last Edit: 24 July 2026, 15:15 by Nino »
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline nadab_sardar
« Reply #2 on: Today at 08:28 »
Nino's covered the wattage side well, so I'll just add a couple of Mk4-specific things. Before spending anything on kit, check what's actually in the car. The factory speakers in a 2002 Golf are pretty weak, and the door cards and mounting rings are often rattly after 20-odd years, so a bit of sound deadening and some proper speaker rings on the front doors makes a bigger difference than most people expect.
For the bass, a sealed powered sub in a small enclosure under the boot floor or in the side is a nice easy way to go if you want punch without losing the whole boot. You'll get tighter bass that way than from a huge ported box, which suits music with a lot of detail as well as the heavy stuff.
Like Nino says, what's your budget? That'll narrow things down a lot.
