Author Topic: brakes slamming - emergency braking  (Read 13453 times)
Offline candywhite12
« on: 23 February 2026, 16:25 »
for no apparent reason, trying to enter or exit my home parking, car barely moving as i am trying to avoid brakes slamming. Exactly what happens though every now and then, both in forward movement as well as in reverse (mostly when in reverse).  No sensitivity settings to change i think, i did try to deactivate front assist altogether but the warning lights come on, with a little screen notification that strongly warns against that.  Ideas?
Current: GTI 8.5, Moonstone Gray, 5dr, Black Estorils 19''. pan, DCC
Wife's: mk8 TSI 1.5 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Son's: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline Dav3smith
Re: brakes slamming - emergency braking
« Reply #1 on: 23 February 2026, 16:31 »
Is it the been activated by a car possibly passing by on the road?
Mine does this occasionally if I'm trying to leave a driveway and there is  a car on the road it slams the brakes on.
Or maybe in your case if the when entering the driveway somehow the height is adjusted if the driveway is on a slant and the sensor picks up something, a flowerpot maybe?
GTI Clubsport ED45 DBP, DCC, HK, WP, Pano
Gone Golf R 7.5
Gone GTI 7
Offline CrunchtheApple78
« Reply #2 on: 23 February 2026, 16:33 »
Yeah, my 7.5 used to do that every so often when reversing into my garage. Used to scare the life out of me as it sounds horrible when it applies the brakes!
Will see if my new CS does it, I’m expecting it will. To be fair I’d rather it be a bit on the sensitive side. It once saved me from a miscalculated reverse!
Offline Dav3smith
« Reply #3 on: 23 February 2026, 16:35 »
Another observation of mine is the car tends to be far more sensitive with the breaks if reversing at 180 degrees as opposed to at an angle.
Gone Golf R 7.5
Gone GTI 7
Offline JoeGTI
« Reply #4 on: 23 February 2026, 18:33 »
Yeah this has come up here before. It’s normal, it’s the front/rear assist thinking you’re about to run into something. The “slam on” is very unnerving to say the least. Makes you think you’ve actually done damage.
I’ve found that if you reverse gently, no sudden movements and have your foot lightly on the brake pedal as you move, then it’s less likely to happen. I guess because the car senses you’re already in control of the braking, albeit gently.
« Reply #5 on: 23 February 2026, 20:52 »
Indeed, covering the brake pedal helps.
I have a 1 inch (3cm for our EU members 😁) -ish lip going into my garage which causes all hell to break loose in the emergency stop department if I clip it as 0.01 mph (very very slow for our EU members 😁) front, rear, parking and god knows what else brakes slam on full if my foot isn’t resting very gently on the pedal.
There’s a junction I have to edge out of occasionally that is quite narrow with houses opposite and a defined hump in the road which really upset the collision gear on my mk8’s but for some reason doesn’t bother the 8.5 as much. I still keep a foot lightly resting on the brake pedal though, just in case.
Offline Adam T7
« Reply #6 on: 24 February 2026, 09:58 »
I have an uphill drive that I reverse down, even after 7 and a bit years it makes me jump out of my skin when it goes off😂😡
« Reply #7 on: 24 February 2026, 20:23 »
i hear all of you, i do have plants one side of my driveway, and it does happen when i reverse in a straight line (which is the only way for me to exit my garage). Do try to keep a light pressure on the pedal but does not always do the trick.  Silencing the constant beeping sound gives me a bit more peace, not thinking that I'll bang into a wall, but the brakes do seem to have a mind of their own and do their thing anyway when they feel like it. I too had a scare the other day with a pedestrian crossing the street out of nowhere, even tho i was simply cruising at something like 5mph the front assist came to the rescue.
« Reply #8 on: 25 February 2026, 16:08 »
Forgot to say in my previous post above, this can be disabled which I did in my Clubsport after the brakes slammed on and seatbelts tensioned as I was reversing very gingerly into a supermarket parking bay causing back and neck pain. The trigger for this was a couple of people wandering between parked cars a significant distance away in another row of cars and the row I was parking in was almost empty of cars (and pedestrians).
I can’t remember the exact settings on the mk8 but I was just reminded of it reversing my car into the garage amongst all the junk with parking sensors screaming away!
Anyway, it’s labelled as Manoeuvre Braking:
Offline Dav3smith
« Reply #9 on: 25 February 2026, 16:56 »
Hhhhmmm this is interesting, I've not delved that low into the bowels of the infotainment system, might take a look next time I'm waiting around in the car. Mind you I've only had the car four years and there's still so much to learn.
Gone Golf R 7.5
Gone GTI 7
