Author Topic: car battery  (Read 20742 times)
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
car battery
« on: 24 January 2026, 10:14 »
morning everyone I'm still having issues with waring pings had all the updates done vw I've heard that the battery must be at least 70% condition wise just wondering which battery is the best to go for and any good deals out there I've also read that the battery needs  to be coded in thanks
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline fredgroves
Re: car battery
« Reply #1 on: 24 January 2026, 10:34 »
Bosch or varta are usually the pick of the brands. I could be wrong but I believe the coding is only necessary if the battery has different parameters to the one you have now (capacity, type etc).
Easiest swap is to look at what you have now and replace it like for like.
Your car is five years old, not unexpected to need a new battery by now.
Offline mossy69
Re: car battery
« Reply #2 on: 24 January 2026, 12:02 »
thanks Fred I was woundering if anyone else had just changed like for like and had no issues
Offline The WolfMan
Re: car battery
« Reply #3 on: 24 January 2026, 21:56 »
This is not correct. You should always code a new battery! They way the battery is charged changes as it gets old. When you put a new battery, you should code it in order for the car to know that has a new battery and restart the "charging method".
This sholud be done in order to maximize the battery life. Of course that you can replace a battery without coding and it will work. The car "sees" 12 V, it works.
I don't understand why Bosch batteries are one of the firsts to be mentioned because I never saw a car with a genuine battery made by Bosch. I'm not saying that Bosch batteries are rubbish, but at least for manufacturers they are not a choice.
Varta, Exide, Moll, Fiamm, Banner. This five brands are OE suppliers. If the genuine is too much I would choose one of these.
Offline Carlosfandango
Re: car battery
« Reply #4 on: 25 January 2026, 17:51 »
Bosch and Varta are exactly the same battery , and neither would be my first choice. YUASA batteries are probably the best available currently. Exide are, as said, also very good, particularly their premium offering.
« Last Edit: 25 January 2026, 18:01 by Carlosfandango »
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Re: car battery
« Reply #5 on: 25 January 2026, 18:09 »
https://www.yuasa.com/uk/info-hub/start-stop-battery-replacement
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline fredgroves
Re: car battery
« Reply #6 on: 25 January 2026, 19:27 »
OK I'm wrong.
In that case pay halfords a fiver for fitting it  :grin:
Offline DrG_GTi
Re: car battery
« Reply #7 on: 26 January 2026, 09:28 »
Unfortunately to fit these types of battery and do the BMS coding is £50 at Halfords, just checked as thought "that's a good idea"...  :smiley:
OK I'm wrong.
2021 Mk8 GTI Clubsport - Reflex Silver
Offline fredgroves
Re: car battery
« Reply #8 on: 26 January 2026, 10:53 »
hmmm thats quite expensive.
I guess its still cheaper than buying something like obd11 (if you have no other reason to need it)
Unless someone who's got one is prepared to help you out.
Personally I'd just get a garage/halfords to do it... just suck it up.
Offline Rudedog
Re: car battery
« Reply #9 on: 26 January 2026, 11:24 »
Has anyone used one of those plug-in diagnostic tools that has a limited number of fixed service functions?
The ones for around £40-50 allow you to put the EPB into the service setting, reset service lights and some have the function to register new batteries.
