Author Topic: car battery  (Read 20701 times)
Offline The WolfMan
Re: car battery
« Reply #10 on: 26 January 2026, 14:05 »
Has anyone used one of those plug-in diagnostic tools that has a limited number of fixed service functions?
The ones for around £40-50 allow you to put the EPB into the service setting, reset service lights and some have the function to register new batteries.
Since most of the MK8 modules are SFD locked I doubt that you can use those tools, at least without paying for a token which is not cheap.
I would look into two options: VCDS or OBD11.
VCDS doesn't have SFD support for now but is planned. The community and documentation are very good. OBD11 is cheaper, as a business model around subscriptions for certain functions and supports SFD.
If you like to work on your car and you say that some workshops charge fifty pounds to code the battery you will hit break even very quickly.
Offline Tarmac_Terrorist
Re: car battery
« Reply #11 on: 03 February 2026, 17:33 »
Bosch batteries are made by Varta - same spec / quality but just different branding
Offline Beebopper
Re: car battery
« Reply #12 on: 14 February 2026, 21:14 »
morning everyone I'm still having issues with waring pings had all the updates done vw I've heard that the battery must be at least 70% condition wise just wondering which battery is the best to go for and any good deals out there I've also read that the battery needs  to be coded in thanks
How did you get on with the battery issue? Mines starting playing up too, got bongs with travel assist warnings when I first drive that clear after a little while, I’m on original battery for a car that’s just over four years old.
I’m thinking about using my CTek charger to do a condition process on it first and see if it’s sorts things out. I’m very dubious how to do this on such a new / modern car with tech like they have. Also aware batteries need coding to the vehicle (such a pain!).
Can I run a recon or charge process with the battery still connected to the car? (I think probably yes, but need to connect the black to the body not the negative terminal).
If I replace like for like battery, does it still need coding? (I think possibly yes, but could get away with not doing that).
Prior - MK2 GTi Big Bumper in White
Current - MK8 GTi Clubsport in Moonstone Grey
(Plus Many other non-Golf hot-hatches in-between!)
Offline The WolfMan
Re: car battery
« Reply #13 on: 14 February 2026, 21:29 »
Chargers like the ones from Ctek are made to charge the battery with it connected to the car. Those who have sports cars who leave the garage once in a while have a charger allways connected to the car.
Yes, even if you replace the battery for one with the same characteristics you need to code it.
Re: car battery
« Reply #14 on: 14 February 2026, 23:39 »
Bosch batteries are made by Varta - just different branding.
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
Re: car battery
« Reply #15 on: 22 February 2026, 18:44 »
hi there regarding the battery issue had the car to vw told me the  battery was fine and it needed and new steering wheel well there's a surprise all good so far by the way that's the 4 th new wheel
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline Beebopper
Re: car battery
« Reply #16 on: 23 February 2026, 17:02 »
I recently did a full standard charge (not recond) using a CTEK MXS5.0 charger, I checked the battery stats with a multi meter after and it was holding 12.7v with ignition off, 12.0v with ignition on, 10.7v during engine cranking and 14.4v whilst idling (all seems normal).
Since charging the battery, I haven’t seen any travel assist warnings or 12v battery circuit errors. I’m monitoring things, but hopefully all remains as normal!
