Author Topic: ESP FAULT  (Read 49044 times)
Offline Norwichdaz
ESP FAULT
« on: 15 January 2026, 18:15 »
As above really.
Tbf I was going to take car into a garage as last week or so has been sounding like a clunk when I set off after letting off the handbrake then for the first few brakes back left sounds like grinding noise but then goes away.
Was going to take it in to check over the caliper etc.
Then tonight I have the car with the squiggly lines lol come up and say esp fault, in the middle of traffic was great fun! The D on the auto was flashing and wouldnt let me move just rev. Didnt know what to do, turned off and on and I could move again.
Google says a sticky caliper could poss be the problem  to set this light etc off.
So have juat booked into a garage to have a look 😬
Offline Snoopy
  • Moderator
  • Geoff.
Re: ESP FAULT
« Reply #1 on: 15 January 2026, 23:50 »
The clunk will more than likely be the pad unsticking from the disc. The caliper maybe sticking slightly and just needcleaning and regreasing. I have to do my Leon ones more or less every year as it lives outside in a wet and windy area.
 The fault code though maybe something else if it wouldn't let you move. A scan will give you more info. Most garages will have a scan tool and see what exact faults are stored.
« Last Edit: 15 January 2026, 23:52 by Snoopy »
Current Garage:
35+ years of GTI ownership.
Offline Norwichdaz
Re: ESP FAULT
« Reply #2 on: 16 January 2026, 07:04 »
Ok ta, yeh "google" says wheel/speed sensor possibly
Offline Snoopy
  • Moderator
  • Geoff.
Re: ESP FAULT
« Reply #3 on: 16 January 2026, 13:55 »
it would put the light on to show their was an abs sensor fault (ive replaced 3 of the 4 over time on my leon for this, using vcds fault tool to find which was faulty) but it wouldn't stop you moving. The warning light are often used to indicate quite a few different faults. I'm thinking maybe mecatronic dsg control unit issue. When was the last time the dsg oil was changed?
« Last Edit: 16 January 2026, 13:57 by Snoopy »
Current Garage:
Offline Norwichdaz
Re: ESP FAULT
« Reply #4 on: 16 January 2026, 17:47 »
Tbh the dsg is prob nearly due for oil change tbf i think .
I've only owned the car 4 mths.
Think maybe gear oil change poss needed then ? Seemed a bit odd it was all at once tho, the abs light came on with the esp fault on dash as I was slowing down for traffic lights and then thats when the D flashing happend.
Offline Norwichdaz
Re: ESP FAULT
« Reply #5 on: 16 January 2026, 18:13 »
Does say possible transmission fluid low too. Praying its a sensor for now lol
Offline Norwichdaz
Re: ESP FAULT
« Reply #6 on: 16 January 2026, 18:14 »
Offline Norwichdaz
Re: ESP FAULT
« Reply #7 on: 17 January 2026, 18:16 »
Abs lights went off as drove to work today, but when I left to come home they came on as started car then went off, then felt the car slightly juddering then the abs and steering wheel light came back on and once that came back on it drove normal again.
When googled it, it said .....again..... abs / wheel sensor and the judders could be the abs trying to activate .
Offline Norwichdaz
Re: ESP FAULT
« Reply #8 on: 21 January 2026, 16:51 »
Front right abs sensor wire near enough had broken off sending the abs etc stupid.
Offline joe6
Re: ESP FAULT
« Reply #9 on: 21 January 2026, 19:23 »
Had that on my mk6. Thought it was the abs sensor until I checked the wiring. Had corrosion in the electrical link to the brake pad as well.
