Author Topic: One year in, starting some mods  (Read 21336 times)
Offline Cbolt18
« on: 27 September 2025, 08:44 »
Hi All, I've owned my 2019 manual pp for about a year now so starting some mods.
Planning a soft dogbone insert, rear sway bar and the Helix sub system for now.
I've also had the rear main seal done under warranty, and then need to be done again. But that's a different story.
Also want to get the diff and gearbox serviced so any tips welcome.
Thanks!
2019 GTi PP manual
Re: One year in, starting some mods
« Reply #1 on: 30 September 2025, 14:46 »
Hi Cbolt  :smiley:
Maybe post some of those things up separately in the mk7 section as there’s a wealth of experience on here.
Another recommendation for a cheap but effective mod on a 7.5 GTI is a PedalBox (or similar from various different manufacturers) have a search on here for lots of threads.
Offline Cbolt18
« Reply #2 on: 30 September 2025, 17:25 »
Hi Exonian,
Thanks for the reply! I'll definitely do some searching and post if needed. The pedalbox sounds interesting, I'll have a look out for that!
Thanks
2019 GTi PP manual
Offline Watts
« Reply #3 on: 30 September 2025, 18:06 »
Hi Exonian,
Thanks
I've taken a pedalbox off recently which was originally on a MK7 manual PP. Let me know if it is of interest, I'll be moving it on pretty cheap. I had it on two cars and it was excellent, transforms the response.
Previously:
Offline Cbolt18
« Reply #4 on: 01 October 2025, 18:26 »
Oh cool, what PB is it? I'll do a bit of research.
2019 GTi PP manual
Offline Watts
« Reply #5 on: 01 October 2025, 19:17 »
It was a DTE/DTUK pedalbox, they don't do them anymore. It has plenty of different settings, just plugs into the accelerator pedal wiring. Exactly like this one in the fitting guide - https://www.golfgtiforum.co.uk/index.php?topic=276517.0
Previously:
Offline Cbolt18
« Reply #6 on: 02 October 2025, 09:01 »
Thanks, I'll have a read.
2019 GTi PP manual
Offline Cbolt18
« Reply #7 on: 02 October 2025, 09:01 »
How easy are they to uninstall?
2019 GTi PP manual
Offline Watts
« Reply #8 on: 02 October 2025, 09:17 »
Took about 5 minutes. You just need to remove the small panel by the pedal for easy access.
Previously:
