Author Topic: 8.5 Coding now available in OBD11 & Carista.  (Read 42352 times)
Offline Carlosfandango
« on: 01 June 2025, 20:26 »
As per title, FYI. there are now a limited range of functions available within both of the above APPS for the 8.5. OBDeleven has a greater range of functions available including some adaptation etc, both have a range of one click options available, but the most important one that I have been looking for since day one, is the ability to permanently switch off lane assist, I do this every trip manually as it just doesn’t work safely in my opinion, particularly on unclassified roads near my home, Carista now has the option to set this as remembering the last status set, so if you switch it off it now stays off until you switch it on again, even after a restart  :smiley:, I can’t see this option in OBDeleven as yet though.
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline Tarmac_Terrorist
Re: 8.5 Coding now available in OBD11 & Carista.
« Reply #1 on: 04 June 2025, 13:14 »
Good to hear. I didn’t renew my OBD 11 due to lack of functionality. Do you know if it can turn off the speed bong permanently as well as lane guidance?
« Reply #2 on: 04 June 2025, 20:18 »
Using OBDeleven it appears that you can yes. 200 credits though if you use the one click option, personally I don’t mind the speed bong as it’s quite subtle.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
« Reply #3 on: 05 June 2025, 23:20 »
Thanks, that’s good to know. I might renew my subscription.
Offline JoeGTI
« Reply #4 on: 06 June 2025, 12:43 »
I tried connecting OBD11 with my car earlier and I'm not seeing any of this. Do you have to do a "scan" of the car first, for these new Apps to appear? The App list for me was very short, I didn't see anything for Lane Assist or Speed warning.
I'll try it again later as I was pressed for time.
EDIT: Actually, I do see the "Traffic sign speed warning" but there isn't an App for the lane assist as far as I can see... And the Speed warning one is 200 credits! Most of the others are typically only 10 credits.
« Last Edit: 06 June 2025, 13:23 by JoeGTI »
« Reply #5 on: 07 June 2025, 12:55 »
Yes, the lane assist option does not show (yet) in OBD11, the screen shot for it is from the Carista app.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
« Reply #6 on: 07 June 2025, 15:36 »
Yes, I have tried twice now and can only see the ability to switch off speed sign recognition but not lane assist strangely, you can switch off the dash symbol for lane assist bit not the actual lane assist.
When I scan, I get about 20 errors for various things on the car, despite everything functioning correctly. I clear the codes but they come back. Never had this with previous VWs / Audis.
I’m finding OBD eleven flakey. I had 200 credits on my Vw obd11 app. They asked me to switch to the new obd11 app and all the credits have gone. The chat / customer services are non-existent. Everything goes into a black hole.
It’s a shame because i am prepared to upgrade from free to ultimate to get free apps but I can’t rely on the functionality or the customer services.
« Reply #7 on: 07 June 2025, 18:15 »
….I also noticed that on the OBD11 website it confirms that for the latest Golf there should be the app available for switching off lane assist, but it’s definitely not there when you connect up the car in the app.   :sad:
« Reply #8 on: 07 June 2025, 20:57 »
When you go to the supported vehicles Using the OBD11 app, the lane assist memory one click app isn’t listed, however, as you point out, it is shown on the website. But! It says “ Attention
First, turn the ignition on and then open the vehicle's hood to activate the app ”
, i didn’t have to do that while using Carista though, so it may make no difference whatsoever, but could be worth a try.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline sipj
« Reply #9 on: 07 June 2025, 21:41 »
Will using tools like odbeleven not cause problems with the warranty?
Current: Golf GTI 8.5. Pure white/black, pan roof, Queenstown, DCC, HK, Area view, spare wheel
Gone: 2018 Golf GTI 7.5 performance pack with standard spec
Gone: 2016 Golf GTE 7
Gone: 2013 Audi A3 S-Line
Gone: 2010 Golf GT TDI
