Author Topic: 8.5 Coding now available in OBD11 & Carista.  (Read 42355 times)
Offline Tarmac_Terrorist
Re: 8.5 Coding now available in OBD11 & Carista.
« Reply #10 on: 07 June 2025, 22:34 »
I’ve tried with the bonnet open but the app isn’t even there to find unfortunately.
Offline Carlosfandango
« Reply #11 on: 08 June 2025, 09:13 »
Will using tools like odbeleven not cause problems with the warranty?
No, the one click apps are essentially just a box ticking exercise, the parameters are already set by VW and are available to activate, a different model or spec car may already be set up like that from new, you’re not changing anything not already programmed in. A remap or such like is a different story though, but even then it wouldn’t void warranty on the whole car, only on components directly linked to the ECU in question. They cannot (and won’t) void warranty on a faulty infotainment screen for example, just because the boost pressure was set to be out of factory tolerances. But blow the turbo up and you’d likely be out of pocket.
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline BikeSausage
« Reply #12 on: 30 June 2025, 19:57 »
Having had my car for 3 weeks now, I looked into Carista /OBD11 as I want to turn off the Soundaktor. I’m not a fan of loud exhausts especially fake ones.
After some digging, it appears that the 8.5 has additional security - abbreviated to SFD2 (Cybersecurity regs?) which the 3rd party dongles have not yet managed to gain access to.
Some diagnostic functions are available but adaptations are mostly not. Which is a shame as I also wanted to enable rear DRLs as my wife always turns the light switch form auto to off and drives around in the darkness with front lights and no rears. 🫣
Mk8.5 GTI
Kings Red Metallic
DCC
19” Queesntowns
Area View
Spare wheel
Electric Tow bar
« Reply #13 on: 30 June 2025, 20:59 »
I’ve just been out in the car, so had a check for you, the Soundaktor adjustment one click app is available for ten credits in my 8.5 using OBDeleven, no rear DRLs from them yet though. Using Carista however there is the option to turn on rear ‘Scandinavian’ DRLs, so both are possible, but sadly only by using both dongles at present.😩
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline monkeyhanger
« Reply #14 on: 30 June 2025, 21:25 »
On my new RS3 (same architecture I presume), my OBD11 (old style, lifetime pro license) won't connect to the car within the app to even try a scan and long coding. I thought it might need the bonnet popped to connect - nope. Thought it might be broken, but works fine on our Cupra Born.
Offline Paul_GTI
« Reply #15 on: 01 July 2025, 00:10 »
I found entering the VIN (continue option I think) works, then selecting the car the next time you connect. Seemed to work for me with the OG dongle.
« Reply #16 on: 01 July 2025, 10:17 »
I will give that a go. Looking at the original OBD11 dongle when plugged in, it's visually doing stuff as you're trying to connect - amber and green LEDs flashing in the casing etc
Offline BikeSausage
« Reply #17 on: 01 July 2025, 11:58 »
Thanks. I shall have another go with Carista, although it would not connect a couple of weeks ago.
Mk8.5 GTI
Kings Red Metallic
DCC
19” Queesntowns
Area View
Spare wheel
Electric Tow bar
Offline Meirk
« Reply #18 on: 05 July 2025, 15:51 »
Also used this method to add my MK8.5 using the original OBD11.
I need to have a look at what I can code manually as coded various things on my last few cars.
I will update the thread with my findings....🤔🤞
Current: Golf MK8.5 GTI 265ps, Delivered Feb 2025, Pure White, DCC, Area View Camera.
Previous: Cupra Formentor 245ps DSG VZ1, Delivered 08/02/2022, Solid White.
Gone: Golf MK7.5 GTI 5DR 245ps DSG, Delivered 16/12/2019, Isaac Blue, Standard Spec.
Gone: Golf MK7 GTI 5DR Manual (220ps Non PP) Build Week 48, Delivered 29/12/2016, Pure White, 18" Austin Alloys, Dynaudio, Car-Net App and Voice Control.
« Reply #19 on: 10 July 2025, 10:04 »
After the suggestion of inputting VIN on OBD11 to get a connection on my 2025 3 week old RS3, finally managed to connect, could see all the modules, was able to clear 8 logged faults, but could do nothing else. None of the modules would open except gateway. Needed to be in central electronics to try and get lane assist to stay off when switched off, turn off audible speed alarm by default and a few other bits. Tried unlocking SFD, to no avail. Hopefully an update to the OBD11 software soon will open these up.
Does VCDS have module access?
Everything is taking an absolute age to connect within. Might be worth getting a Carista unit if that works.
