Author Topic: POTHOLE DAMAGE - REPAIR COSTS  (Read 8510 times)
Offline Sniffer
« on: 04 April 2025, 18:24 »
I hit a large pothole and recently noticed that my steering wheel was slightly off centre, so I asked my local dealership, yesterday, to check this when the car was in for its first oil service.
They didn't do the additional work I requested because they said they didn't have time, and I've got to book it in again. But, they added that the initial assessment (4 wheel alignment check) will cost me £299 and, if any repair work is required, it will cost significantly more. Apparently, if the steering/tracking needs adjustment, then the Adaptive Cruise Control etc also needs recalibrating, and that's another £300 or so. They didn't say exactly how much all this is likely to cost but I suspect it won't be cheap.
It seems, gone are the days when your local tyre dealer could sort out your tracking in 15 mins, for just a few quid in cash! BTW, I do know that some of the larger, nationwide tyre dealers claim they can do specialist 4 wheel alignment and cruise recalibration work but I'd be rather wary of using one of them. On the plus side, I suppose they'd be significantly cheaper than a VW main dealer.
 Has anyone else encountered similar pothole related issues and, if so, what was the outcome?
1981-84 Mk1 Golf GTI (Black);
1984-86 Mk 2 Golf GTI (White);
1986-88 Scirocco GTX (Graphite)
Gap - The Sensible Years (Mostly)
2016 Mk 7 Golf GT TDI; (Silver)
2018 Mk7.5 GTI DSG (Red)
2020 - Mk 8 GTI DSG (White)
2021 - Mk 8 GTI DSG (Pearl Black),19"Adelaides
2024 - Mk 8 GTI DSG (Kings Red), 19" Adelaides
2026 - Mk 8.5 GTI DSG (Dolphin Grey) 19" Estorils, DCC, Exterior Styling Pack, Area View Camera, Winter Pk etc - May 2026
Offline Adam T7
Re: POTHOLE DAMAGE - REPAIR COSTS
« Reply #1 on: 04 April 2025, 18:46 »
I had 4 wheel alignment done when the front arms were changed - cost £66.00. Mines a 7.5 with ACC but I’m sure the process is not significantly different?
Done with local GTI specialist.
Offline Watts
« Reply #2 on: 04 April 2025, 19:03 »
Same here. £299 is outrageous. If a decent tyre centre couldn't do alignment on cars with radar they would soon go out of business, loads of cars have it now. I also reckon the chances of a dealer doing it in-house is unlikely, they probably take it elsewhere anyway.
Previously:
Offline Carlosfandango
« Reply #3 on: 04 April 2025, 21:10 »
The adaptive cruise will not need recalibrating after a simple 4 wheel alignment, take it to an independent local tyre place that has a Hunter alignment machine, will cost around £100 for 4 wheel or less for two wheel. unless there is a good reason, I only have the two wheel alignment if I ever need it doing, as they will nearly always knock the other two out when they do the other ones, and in the process of aligning the 2 you’ve paid for, have to put all 4 back into alignment.
« Last Edit: 05 April 2025, 06:21 by Carlosfandango »
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline davo245
« Reply #4 on: 05 April 2025, 08:16 »
299 is the most ridiculous price i have ever heard as said if you pay over 100 you are being ripped off you wilont need any radar calibration either after 4 wheel alignment.
Had it don on my previous 7.5 performance and cost 77 all in.
Would also use another dealer in future as that one is clearly useless rip off merchant.
They don't do it on site either just take it to some one else and pay possibly 40 quid as they have a contract with tyre place then charge tlypu 299!
Nice bit of buisiness that is.
Even if they were doing it it takes half hour si even there hourly rate can't be that much!
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline joe6
« Reply #5 on: 05 April 2025, 09:31 »
Many tyre dealers have free alignment checks but beware the cost if changes are required! As already said 4 wheel alignment is about £100 or less and can be a bit fiddly as changing front or rear usually means resetting the other axle and make sure they use the correct car mark (eg mk8) and version (eg clubsport etc). Resetting ACC etc is not required for simple wheel alignment changes. The tolerance on these are larger than any changes caused by wheel alignment.
Offline P6GTD
« Reply #6 on: 05 April 2025, 16:52 »
ATS Euromaster did a free check for me and showed the measurements to me on a screen. Fortunately my alignment was still almost perfect but I’m sure they said worst adjustments would be around £80.
I get my alignment checked every 18 months and don’t recall paying more than around £60.
Offline Hampshire rubber burner
« Reply #7 on: 06 April 2025, 17:02 »
I work in a fast fit centre and bosch trained
ANY WHEEL ALIGNMENT THAT CHANGES STEERING ANGLE/ DRIVE LINE WILL REQUIRE ADAS CALIBRATION
THATS RADAR AND CAMERA
IF NOT CALIBRATED THEN ACC LANE ASSIST BLIND SPOT PEDESTRIAN DETECTION AND
SIGN RECOGNICIAN WILL NOT WORK
IF NOT DONE YOUR CAR INSURANCE COULD BE VOID
Offline Adam T7
« Reply #8 on: 06 April 2025, 19:51 »
My ADAS and ACC works absolutely fine post alignment.
« Reply #9 on: 06 April 2025, 20:28 »
Yes indeed! It will carry on working fine much as it would if you knocked it out of alignment.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
