Author Topic: POTHOLE DAMAGE - REPAIR COSTS  (Read 8512 times)
Offline Adam T7
Re: POTHOLE DAMAGE - REPAIR COSTS
« Reply #10 on: 06 April 2025, 22:20 »
My ADAS and ACC works absolutely fine post alignment.
Yes indeed! It will carry on working fine much as it would if you knocked it out of alignment.
What are the symptoms of a fault (apart from crashing)?
« Last Edit: 07 April 2025, 08:02 by Adam T7 »
Offline joe6
« Reply #11 on: 07 April 2025, 12:27 »
Warning lights on dash possibly esc may not work, lane assist error and associated driver assistance errors. Main problem is usually scs and that can easily be checked with obd11.  Not had a problem when checking scs after alignment so assumed rest was OK. The hunter alignment system has an add on that interrogates the sensors and resets to manufacturers spec if  necessary.
Offline Adam T7
« Reply #12 on: 07 April 2025, 14:56 »
Thanks, nothing like that on mine since work done in early December. Don’t use ACC much but Anti collision seems fine (apart from when the front sensor gets covered in snow).
Offline davo245
« Reply #13 on: 07 April 2025, 17:44 »
I work in a fast fit centre and bosch trained
ANY WHEEL ALIGNMENT THAT CHANGES STEERING ANGLE/ DRIVE LINE WILL REQUIRE ADAS CALIBRATION
THATS RADAR AND CAMERA
IF NOT CALIBRATED THEN ACC LANE ASSIST BLIND SPOT PEDESTRIAN DETECTION AND
SIGN RECOGNICIAN WILL NOT WORK
IF NOT DONE YOUR CAR INSURANCE COULD BE VOID
REALLY!?🤔
« Last Edit: 07 April 2025, 21:49 by davo245 »
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline DrivenToDistraction
« Reply #14 on: 07 April 2025, 19:58 »
I agree with you Adam. I got the tracking redone in my Focus ST (recently changed from an 8.5 GTI) a couple of days ago following a couple of 'pothole incidents'. All the Driver Assist systems (radar and camera based) continue to work absolutely fine and the steering feel is now perfect (better than when I bought it). Work was done at an F1 Autocentre. All in (diagnostics and front + rear realignment) £84 - took just over an hour all told.
Ford Focus ST Mk 4.5
Gone: Mk 8.5 GTI in Dolphin Grey
Gone:2017 Mk 7.5 GTI, manual, black.
Offline Sniffer
« Reply #15 on: 08 April 2025, 17:25 »
Thanks for all of your helpful comments.
I have queried the £299 quote from my VW dealership and they attempted to justify it, by saying the job involves a long test run and around 2 hrs labour, involving checking all of the steering components. Wow, are they now charging £150 per hour?
Anyway, I told them thanks but no thanks and I have now booked my car into a local tracking and suspension specialist, who come highly recommended and significantly cheaper. They have all of the latest alignment and ADAS kit on their premises, too. Their prices start at around £80, depending on what needs done, which seems a lot more reasonable than the main dealers.
As some on here have said, the dealership quote was a real rip off and I bet they don't even do the job in-house.
1981-84 Mk1 Golf GTI (Black);
1984-86 Mk 2 Golf GTI (White);
1986-88 Scirocco GTX (Graphite)
Gap - The Sensible Years (Mostly)
2016 Mk 7 Golf GT TDI; (Silver)
2018 Mk7.5 GTI DSG (Red)
2020 - Mk 8 GTI DSG (White)
2021 - Mk 8 GTI DSG (Pearl Black),19"Adelaides
2024 - Mk 8 GTI DSG (Kings Red), 19" Adelaides
2026 - Mk 8.5 GTI DSG (Dolphin Grey) 19" Estorils, DCC, Exterior Styling Pack, Area View Camera, Winter Pk etc - May 2026
Offline davo245
« Reply #16 on: 09 April 2025, 07:20 »
They are 100% ripping you offer NEVER use that dealer again bet you pay £100 max at local for tracking with no calibration to anything else.
Mk6 GTI DSG
Mk8 GTI
