Author Topic: Battery low voltage  (Read 45701 times)
Offline Usedit67
Battery low voltage
« on: 16 March 2025, 12:49 »
My 2020 PP is starting fine and stop start is working fine. However, my battery voltage seems to always be low. Today, voltage was 11.9v after sitting for 2 days. Even after a run, it's rarely more than 12.3 V. I've only recently bought the car (VW Approved) so if the battery is on the way out, I'd look to having it replaced. I know that the car has some type of intelligent charging so maybe it just maintains enough charge? I've checked with the engine running and the alternator seems good. Any advice appreciated. Cheers
Offline Mutley75
Re: Battery low voltage
« Reply #1 on: 28 March 2025, 21:45 »
2019 plate with 33k miles - exactly the same.  Thought it needed replacing as there seems to be a red indicator light on all the time. Garage tested it and said it was fine just needed a good charge. Bought a charger off amazon, charged it up over 48 hours. Checked it again a couple of days later and it’s right down low again.  That said, not had any issues at all so just ignoring it now. I only do 1-2 trips per week, no more than 50 miles a week.
Golf GTi Performance Edition (2019), 5dr, DSG in Isaac Blue, Dynaudio & Brescia alloys.
Offline Adam T7
« Reply #2 on: 29 March 2025, 07:24 »
Turn stop / start off.
Offline Usedit67
« Reply #3 on: 29 March 2025, 07:38 »
Offline Mutley75
« Reply #4 on: 29 March 2025, 08:13 »
I always do!
Offline Wayne.R
  • "If in doubt.....Flat out"
« Reply #5 on: 23 December 2025, 18:06 »
Or just code it out, using OBDeleven. I hate SS. PITA. So used a 10 credit option and turned it off permantantly.
2016 Tornado Red, GTI PP, DSG, 5 door
Offline petec
« Reply #6 on: 23 December 2025, 18:29 »
Back along (early part of 2025) my 2018 seemed to half stall randomly when coming to a stop as if the SS was active (although I switch it off every journey), believe there's a service bulletin which recommends battery replacement in such cases, that done and never seen the problem since..
Offline mcmaddy
« Reply #7 on: 24 December 2025, 12:39 »
Can't be coded out on later model years though 👍🏻
Offline Carbon VW
« Reply #8 on: 05 January 2026, 16:46 »
2013 gti here with stop start coded out for many years still on the original  EFB battery and it’s healthy ! Drive the car more to give it a good recharge. If you’re only doing short trips your battery will be toast in 3-4 years. My wife also has a golf and she’s on her 3rd battery on a 2016.
« Last Edit: 06 January 2026, 10:57 by Carbon VW »
Mk7 CSG GTi 6MF Stage 1, CSS backbox
Offline scottm1
« Reply #9 on: 09 January 2026, 17:35 »
Just jumping on this, have a MK7.5 PP 5 years old and got a low battery on Sunday and it wouldn't start. Jumped it and it has worked all week but took it to Halfords for a test and they said it's at 48% and needs replaced.
It has been running fine this week and had it in at VW for an MOT today, vehicle health report showed no issues with the battery. Went to start it to leave VW and the battery had died again and needed to get them to jump it!
I can get a new battery from Halfords but wondering will they code it? The guys at VW said you don't need to do this but tbh not sure I trust them!
