Author Topic: DSG - manual changes  (Read 10655 times)
Offline Tarmac_Terrorist
« on: 08 March 2025, 22:22 »
Picked up my new 8.5GTI in Friday and really pleased with it so far. Much more engaging to drive that yhe RSQ3 that I traded in. Only small annoyances are having to switch of stop/start, lane changing alert and speed donging nonsence.
I often like to paddle shift manually. In my previous Audi I could select manual mode and it stayed in manual. Am I missing something simple? I can’t see how to select manual mode from the little gear select nugget.
Offline JoeGTI
Re: DSG - manual changes
« Reply #1 on: 08 March 2025, 22:47 »
You can’t do it from the “nugget”. You need to do it from the paddles on the wheel. It will stay in manual M mode unless you deliberately switch it back to D/S again via the nugget.
Offline Carlosfandango
« Reply #2 on: 09 March 2025, 00:37 »
It will only stay in manual mode temporarily if you use the paddles while in D, but, it stays in manual if you use the paddles while in S, you can also manually switch back to auto by holding in the right (+) paddle for a second or two. 👍
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
« Reply #3 on: 09 March 2025, 16:53 »
Thanks for the information. That’s disappointing that it only stays in manual in sports mode. My previous car you could knock the Dsg lever to the left and use manual without it switching back.
« Reply #4 on: 09 March 2025, 23:56 »
It doesn’t have to be in sport mode, S on the gear selector is sufficient, it will however hold a gear in D if you are descending a hill for instance, this is because the car has an inclinometer and ‘understands’ you are not on level ground,  the car also appears to be able to deduce wether you are still using the paddles or not in D, throttle inputs etc indicate to the ECU that the driver has not relaxed and waits to see if another paddle input is actioned, only when it is clear that a manual gear change is not going to take place does it revert to auto, usually this occurs when the ECU expects and needs a gear change that is not forthcoming.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline Dogman12
« Reply #5 on: 18 March 2025, 09:11 »
Why do you like 8.5 GTI more than RSQ3 in terms of driving perspective? I heard 8Y RS3 has a lot of turbo-lag, and really not going anywhere under 3000 rpm. Curious to hear your thoughts and comparison!
« Reply #6 on: 18 March 2025, 22:01 »
The engine itself in the RSQ3 was a peach. However, the rest is little more than a that a mis-match of parts from the VAG parts bin. Throttle response was dreadful. The gearbox slow, indecisive and clunky (it’s apparently the same DSG box from a T6! The suspension was so hard, it crashed down the road and jumped about on bends. It’s a heavy car too and you know it. The interior isn’t as nice as a GTI either - the GTI is much better quality fittings and plastics. It felt more like  CVT gearbox than DSG. The Volvo XC90 T6 which I had previously was a much more responsive car. No way should it have ever been a £60k car.
I chose to go back to a GTI as the last car I really, really liked was. mk5 GTI. I didn’t even have any interest in the Golf R - I find it a bit boring to look at compared with the GTI. The thing is, when a car passes a certain level of performance, you simply cannot ‘use’ that performance on the road. If you want to have a spirited drive, the front wheel drive of a GTI is far more engaging and challenging to the driver than say, a Golf R, which has more traction.
I only picked up my GTI a couple of weeks ago but I’m really smitten with it - i feel that I am ‘driving’ it rather than simply ‘operating’ it, as it feels with so many modern cars. Over the years, I learned some hard and expensive lessons. Faster, is most certainly not always better - only if you like pub performance stats and bragging rights.
« Last Edit: 18 March 2025, 22:06 by Tarmac_Terrorist »
Offline DrG_GTi
« Reply #7 on: 19 March 2025, 14:39 »
Also worth noting that if if you hold the left (-) paddle it will put in M (if not already there) and change down to the most appropriate gear for a fast overtake
2021 Mk8 GTI Clubsport - Reflex Silver
Offline Beebopper
« Reply #8 on: 19 March 2025, 15:41 »
I've never had a DSG or auto car before the Golf, I quite like it to be honest and is easy to drive around town, and then open up on the back roads. The only bit that annoys me, is even if in manual mode it changes up automatically when you near the red-line. So not quite manual in that sense.
Prior - MK2 GTi Big Bumper in White
Current - MK8 GTi Clubsport in Moonstone Grey
(Plus Many other non-Golf hot-hatches in-between!)
Offline fredgroves
« Reply #9 on: 19 March 2025, 15:46 »
I think the current R doesn't auto shift up... Or you can get new dsg software to change that...
