Author Topic: DSG - manual changes  (Read 10657 times)
Offline Beebopper
Re: DSG - manual changes
« Reply #10 on: 20 March 2025, 06:33 »
I think the current R doesn't auto shift up... Or you can get new dsg software to change that...
That’s interesting, I’m assuming the DSG software to do this would be aftermarket, like having an ECU remap?
Prior - MK2 GTi Big Bumper in White
Current - MK8 GTi Clubsport in Moonstone Grey
(Plus Many other non-Golf hot-hatches in-between!)
Offline fredgroves
« Reply #11 on: 20 March 2025, 08:07 »
Yes a company called TVS are the best probably.
The whole thing can be customised to how you want it.
Offline Carlosfandango
« Reply #12 on: 20 March 2025, 11:41 »
 when the transmission is locked into its manual mode, kickdown and automatic change-ups are deactivated, putting the task of the perfect shift squarely on the driver. Not sure if it applies to the non performance R and GTI’s or not?!
Source:
https://www.rushmagazine.co.uk/post/revised-2025-volkswagen-golf-r-mk8-facelift-unveiled
Also talked about here by Benny Leuchter and Misha Charoudin.
https://youtu.be/vjrQK2E-r5w?si=ldj4awUKlp0s7iAr
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline Rudedog
« Reply #13 on: 20 March 2025, 11:51 »
Although there is no auto upshift with the R I would hope that there is some kind of DSG protection built in - would it be possible to accidently buzz the gearbox with a miss-shift or keeping it at the redline for extended periods.
Offline fredgroves
« Reply #14 on: 20 March 2025, 14:04 »
It will hold max revs at whatever max revs is set to.... just like a manual... up to you if you blow the engine but it will be a limit that is safe (unless you tune the box to less safe!)
Offline fredgroves
« Reply #15 on: 20 March 2025, 14:38 »
Definitely R only, whether thats just PP version I don't know. Its definitely not clubby or GTI.... without TCU software swap anyway
