Author Topic: Part number question  (Read 4610 times)
Offline 2007GTI
« on: 15 February 2025, 21:14 »
I need a new right temperature flap positioning motor, as it’s faulty.
I pulled it out of the car today, absolute pig to get out, and the part number is stamped on it is:
5Q0907511K
My question is, there seems to be many variations of this part, I messaged someone on eBay who has 5Q0907511A advertised, they said as it’s not the exact same as mine, as it has A on the end, not a K.
I was always under the impression the letters on the end meant a revision or something?
There are also ones advertised without an extra letter on the end, so 5Q0907511.
Can anyone shed any light?
Cheers.
Offline Finglonga
Re: Part number question
« Reply #1 on: 15 February 2025, 23:24 »
Yep the letter on the end is the revision number. The "A" should fit but they fore some reason have been improved. Could simply be more glue on the foam seals. Have you checked the price of a new one from VW as on some rare occasions they are pretty decent prices on somethings.
Offline 2007GTI
« Reply #2 on: 16 February 2025, 08:15 »
Thanks, here’s the thing, before I pulled it off the car, my mechanic checked with VW and they said the part no is 5Q0898511 it’s £132.16 inc vat. Middle three digits different?
« Last Edit: 16 February 2025, 08:31 by 2007GTI »
Offline joe6
« Reply #3 on: 16 February 2025, 15:51 »
Suggest you check on lllparts. There is a parts diagram for golf gti 2013 to 2020. The two numbers you have are for right and left flap motors so the part number on the one you removed is likely the correct one. Can't help with the letter at the end. As Finglonga suggest likely a revision number.
Offline 2007GTI
« Reply #4 on: 16 February 2025, 16:07 »
Thanks, exactly which drop downs are you using, when I put it in nothing comes up
Offline madstaff
« Last Edit: 16 February 2025, 17:20 by madstaff »
Offline 2007GTI
« Reply #6 on: 16 February 2025, 18:35 »
Thanks, but when I tap item 23 it says “No products were found in this category.”
Offline SRGTD
« Reply #7 on: 16 February 2025, 18:57 »
Doing a separate internet search on the part number returned the LLL Parts website in the search results. Clicking on it gives the following screen, which suggests you can order the part from them.
Here’s the link to the screen below;
https://www.lllparts.co.uk/product/volkswagen-5q0898511-control-motor-for-temperature-regulating-flap/mpn/5q0898511
« Last Edit: 16 February 2025, 19:00 by SRGTD »
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline 2007GTI
« Reply #8 on: 16 February 2025, 19:14 »
Thanks all, I’ve found someone on eBay who sells recon ones for a third of the price!
